new front forks calipers wont fit them
- yggy
- more wrenching than riding!
03 Jun 2010 14:25
Hi Peeps..
i got myself a "new" set of front forks, the previous owner mentioned that these would fit my bike and calipers.
the fittings for the calipers seem 0,5 inch(1cm) lower than my old front fork caliper fittings. so i cant fit them, rats..
is there a simple solution possible here? swap the caliper brackets around or something? or am i screwed? do i need to get matching calipers ?
piccies:
fitted new fork:
old fork, caliper fitting sits higher:
caliper:
the reason i wanted to swap is that one my old forks the studs that sit on the bottom are a write off, can i get those out and replace them easy? they look pretty darn solid in there..
any help would be aprreciated.. thx!
piccies:
fitted new fork:
caliper:
1980 EU-z650 c4 one of the few C's around..
- otakar
Re: new front forks calipers wont fit them
03 Jun 2010 14:29
We would love to help you but we need more info about the bike the forks the calipers and more pictures.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- yggy
03 Jun 2010 14:35 - 03 Jun 2010 14:36
Hi,
the bike is a 1980 C4 z650 (european), not many about i believe.
i dont know what extra info you need for the calipers, nor the forks.. but ill make some more detail pictures of both the old and new forks tommorow morning.
thx!
thx!
Last edit: 03 Jun 2010 14:36 by yggy.
- DoubleDub
03 Jun 2010 14:36
What are the new forks originally from?
- yggy
03 Jun 2010 14:39
thats the problem, the bloke said they came from a c2 or c3 (close to my c4) hence i bought them, where only 30 dollars, so not that bad sale actually.. stupid me thinking that all those forks have all the stuff in the same place
- PLUMMEN
03 Jun 2010 18:03
studs in bottem of forks will screw out
- otakar
03 Jun 2010 19:52
I believe that your C4 may have gone to a larger disc over the c2 and c3
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Bluemeanie
03 Jun 2010 21:01 - 03 Jun 2010 21:03
KZ650C4 1980
The last C, the C4 was on the market in 1980. The C4 was much the same as the previous C3 but it got some of the upgrades from the new F series. The ignition and stator covers where ribbed and it got a plastic cover under the headlight covering the brake lines. You could get it in two colors: Candy Persimmon Red and Black Pearl. It wasn't sold on every market so there are not quite few around.
Last edit: 03 Jun 2010 21:03 by Bluemeanie.
- yggy
03 Jun 2010 22:05
@plummen
Ok do I need to put some heat on the forks to get them out? My grip tool keeps slipping on the bolts. Maybe they used one of those heavy duty loctites in there.
- Zthou1977
04 Jun 2010 02:28
Yggy,
The twin-disc Z650 has smaller diameter discs than the single-disc model.
A few days ago I had to remove some fork studs that were really stuck in there. Take a Dremel or similar with a cutting disc and remove some material on both sides of the stud, so you get two parallel flat surfaces. Use some penetrating oil and let it sit for a while. Put the flattened end in a bench vice and twist the bolt out gently but firmly. While you do this, watch carefully for signs that the bolt is deforming (you do not want to snap it off).
Good luck & don't worry, it'll come out fine.
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
- yggy
04 Jun 2010 02:38
ah thx Zthou1977
ill give that a try once im home from work tonight. or maybe first put some wd40 on the studs first
hmm, it feels that my twin disc setup are bigger.. ah well if i can get the studs out ill replace the forks back for now. i am only stressed for time as i need to have a running zed in 2 weeks, becasue im participating in a large scale tour where we visit 4 countries
(germany-france-luxembourg and belgium , gonna be awesome! )
thx again..
thx again..
- otakar
04 Jun 2010 05:38
I just take THREE nuts and tighten them against each other and than use the inner most nut to remove the stud, plus you can warm up the aluminum with a heat gun, DO NOT USE A TORCH.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
