Painted Wheels???
  • Fozzie
  • Fozzie's Avatar Topic Author
Painted Wheels???
31 May 2010 16:45
#372425
I've been thinking about painting my wheels. Any suggestions? I keep polishing the aluminum areas on them now but in a few days they are dull and oxidizing again. Thinking about having them painted at work, black maybe. Are there any issues I may be overlooking(air leak, balace etc)?
1982 KZ1000J
  • dejavoodo41
  • dejavoodo41's Avatar
Re: Painted Wheels???
31 May 2010 16:52
#372429
If you polish them and then clear coat them that should cut down on the oxidation. I know that most of your aftermarket automotive aluminum wheels come clear coated to prevent oxidation.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • JMKZHI
  • JMKZHI's Avatar
01 Jun 2010 07:49 - 02 Jun 2010 07:04
#372570
You might try wet sanding the unpainted areas w various grits, then polish. I refurbished a set of cast alloy wheels. For the silver surfaces I used 400/600/1500 grit wet sanding paper, then I polished w BlueMagic metal polish which supposedly leaves behind a silicone film.
For the painted areas I used sand paper, wire wheels & dremel attachments to scuff up the old paint. I applied grease to the raised silver areas that I did not want painted, then sprayed them w engine paint. After the paint dried to the touch, I wiped off the grease w a shop cloth. Then I baked the wheels in a low temp oven to cure the paint (wheel bearing removed).
Last edit: 02 Jun 2010 07:04 by JMKZHI.
  • Fozzie
01 Jun 2010 19:05
#372705
Might be a bit much to ask but any close up pics?
1982 KZ1000J
  • bountyhunter
  • bountyhunter's Avatar
01 Jun 2010 19:58
#372715
Once they are painted, you have a never-ending lifetime job to keep them up. If they are aluminum, you might want to get them anodized.
Many new car wheels are clear coated with urethane, and you have to be very careful not to scratch them and also you can't use strong cleaners on them. In a few years, they look like crap. You should see my wife's Saturn wheels....:ohmy:
  • JMKZHI
  • JMKZHI's Avatar
02 Jun 2010 06:32 - 02 Jun 2010 06:34
#372792
The paint is holding up fine & the polished areas are as well. It has been my experience that baking the parts in the oven toughens the paint. The DupliColor engine enamel comes in gloss, semi-gloss & low gloss. I chose semi-gloss.
Last edit: 02 Jun 2010 06:34 by JMKZHI.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
02 Jun 2010 06:41
#372795
Whatever you paint with, first use a good "self etching" primer ;)
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • JMKZHI
  • JMKZHI's Avatar
02 Jun 2010 06:43
#372796
The photos are the best I've got. The wheels were in poor condition - they're from an 80 550. I think they came out pretty good. But if your bike is super duper mint condition nice, then they might not pass muster.
  • JMKZHI
  • JMKZHI's Avatar
02 Jun 2010 06:53 - 02 Jun 2010 07:11
#372797
I don't prime parts that I expect to bake in the oven. Nor do I use primer w brake caliper paint or bar-b-que grill paint. I refurbished my front brake caliper several years ago w no problems at all & the paint still looks new - I baked it in the oven to cure it. I spray the back side of chrome parts w bar-b-que grill paint to deter corrosion - those don't get baked since it doesn't seem necessary. I checked an exhaust heat shield after a few years - the paint was still perfect & there was no tell-tale corrosion anywhere.
I forgot to add that on parts that I don't expect to bake, I use a rust converter prior to spraying the bar-b-que paint. It may not be necessary, though, since you're supposed to be able to spray barby paint over light rust. But I hate rust, so I go ahead & do it.
Last edit: 02 Jun 2010 07:11 by JMKZHI.
