81 kz550 rear sets
  • boostngearhead
  • boostngearhead's Avatar Topic Author
81 kz550 rear sets
27 May 2010 17:53 - 27 May 2010 18:05
#371483
Ive been looking for rear sets for my 81 kz550 and can only find rear sets that fit a '81 kz500 and another set that fit '82-'83 kz550. Anyone shed some light on compatibility? I emailed fastfromthepast.com and they said neither would fit my bike, which makes sense or itd be listed...
I also found some from spec2.com that are suppose to fit, which would be nice other than the only contact info is a phone number, not exactly secure ordering... Has anyone dealt with this company?
Also found Raask, and they have some that are made for my bike. The question is quality, the tarozzi rear sets look like higher quality. Any opinions there?
Thanks for any help ahead of time!
Last edit: 27 May 2010 18:05 by boostngearhead.
  • mjg15
  • mjg15's Avatar
Re: 81 kz550 rear sets
27 May 2010 19:29
#371504
If you just want to move the pegs back and aren't interested in trickness or aesthetics then I'm pretty sure that you could put the pegs and shifter from an '81 GPz550 on there. They would probably move the pegs back 2+ inches and should be readily avail on ebay.
KZ500 parts should be similar, as should 82-83 KZ550.
Post links to rearsets if you get a chance
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • loudhvx
  • loudhvx's Avatar
27 May 2010 19:45
#371511
Don't deal with SPec II. I ordered some stuff 7 or 8 years ago and I'm still waiting to hear from the guy. It seems like a one-man operation over there and it's one grumpy man. ...not fun to deal with.
What model bike do you have. In 81 there were at least 3. The gpz, the LTD and the standard. They all had different pegs, but as mjg15 mentioned, you might be able to swap some from a gpz onto your bike.
  • boostngearhead
27 May 2010 20:04
#371532
81 kz500 rear sets
www.fastfromthepast.com/servlet/the-107/...-Fixed-Rubber/Detail
82-83 kz550 rear sets
www.fastfromthepast.com/servlet/the-133/...-Fixed-Rubber/Detail
both from fastfromthepast.com
good to know on the gpz parts, ill look into it.
Also good to know about spec2, thats honestly what I assumed just by the website.
My bike is the standard kz550A
  • mjg15
  • mjg15's Avatar
27 May 2010 20:20 - 27 May 2010 20:21
#371540
The GPz pegs will definitely bolt on the stock mounting bosses on your frame. The KZ pegs are located in front of the mounting bolts and below them. The GPz's are behind and above. Both use the same mounting point on the frame. That's the good news....the bad news is the GPz shifter has a linkage that has a pivot point that is located on the countershaft sprocket cover. getting a GPz cover may be cheaper and easier than modding a KZ cover. The brake lever may or may not interfere with the GPz peg. I have both bikes in the garage so I can take a look and a couple pics tomorrow if you'd like. All these parts are regularly on ebay.
BTW nice 550, I'm hoping to put together a green one this season
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 27 May 2010 20:21 by mjg15.
  • boostngearhead
27 May 2010 20:37
#371550
Thanks for all the info! Im prolly not going to go with the gpz setup tho. Id like the controls further back then what the gpz setup can offer, the bikes going cafe. Im seriously looking at raask rearsets, comes with linkage and everything bolt on, very clean looking.
Thanks for the compliment! So far it has pipe, pods, jets. Next is cafe seat, rear sets, front/rear springs.
  • mjg15
  • mjg15's Avatar
27 May 2010 21:09
#371556
The Raasks are nice.
You will find that shocks and forks springs will make a BIG difference.
Check out the GPz550 forum for a ton of 550 info
www.nwsca.com/scripts/gpz_forum_2005/default.asp
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
