foward controls
- hmeric7
foward controls
26 May 2010 19:14
has anyone madea set of foward contols for these bikes. ive been ponderin makin a set because im going build bobber and would l like to stretch my feet out but havent seen a set on anyones rides.
1977 KZ 1000 LTD
- djturnz
Re: foward controls
27 May 2010 03:51
If you branch out to some of the jap friendly chooper sites, you'll see lots of home made controls. Also, TC Bros sells forward controls for some of the metrics. They use the front motor mount bracket.
chop cult
chopper underground
club chopper
all have Japanese bike sections.
chop cult
chopper underground
club chopper
1982 KZ750 (4) LTD
- mart13
Re: foward controls
27 May 2010 04:23
i made mine out of an old pair of rearsets , some pegs and some scrap steel from the offcuts pile , if you sort the positioning out for your feet first the have a look to see if theres anywhere to mount them , if not weld tabs on to your frame to mount them , just make sure the you dont interfear with anything else
if you can find one of these that fit your gearchange shaft it will make life easier
if not you'll have to make one out of a kz gear peg
you might need to bend the connecting rod to to fit but thats easy enough and using a sportsbike rear brake master cylinder will make it loads easier sorting out your rear brake
if you have a drum brake you may need to get creative to sort out the brake rod
