Tire Size Question
- Fozzie
Tire Size Question
23 May 2010 17:16
So my rear tire is a 130-80-V18. What does the V mean in the tire size? I'm looking at tires and I can't find one that has a "V" in the size. Will a 130-80-18 work, or does it have to say V18? The current tire I'm running is a Metzler but I need to replace it, has cracks in it. Any recommendations or a good tire? Considering Kenda(thats what is on the front).
1982 KZ1000J
- Nebr_Rex
Re: Tire Size Question
23 May 2010 17:39
Fozzie wrote:
V is the speed rating.Your parts dealer can help pick out the right rating for your bike.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Fozzie
23 May 2010 17:42
Speed rating? Ok thanks! Thought it was more to it than that. Just getting antsy, the bike shops are closed on sundays and mondays so it'll be a few days before I can inquire about some new rubber. Thanks.
1982 KZ1000J
- dejavoodo41
23 May 2010 17:44
A speed rating of V means that it is rated for sustained speeds of up to 150 mph.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- H1Vindicator
Last edit: 21 Feb 2013 01:59 by H1Vindicator.
- Fozzie
24 May 2010 16:28
All the tires are confusing me. I found a tire Iam considering but not sure if it will fit. It is a 130/80B-18 rear. It is an H rated tire but now what does the B mean? Will it fit my bike?
www.americanmototire.com/catalog/product...269&products_id=1812
theresthelink to the tire.
1982 KZ1000J
- Fozzie
24 May 2010 17:09
Ok, so I think the B stands for Bias Ply? So now my next question is will a Bias ply be ok to use? I read where it has more wear and shorter life than a radial but the price is pretty decent.Anyone using a Bias ply tire?
1982 KZ1000J
- H1Vindicator
Last edit: 21 Feb 2013 02:00 by H1Vindicator.
- trianglelaguna
24 May 2010 17:29 - 24 May 2010 17:41
you can get a killer set of avon roadriders in your sizes with the V rating delivered to your door for 200 and either get em mounted at a local shop (and balanced)for about 50 off the bike...or mount em yourself by watching some youtube motorcycle tire mounting clips.. and buying 20$ tire irons online or at a shop...i do mine and am getting smoother at it..plus i can clean the rims up and set all my adjustments myself.....almost like doing your bikes tires as a kid.....
here is a link to the am26 roadrider...another member here gave me a link to a cheaper deal on a set ....maybe they will chime in
www.shopmotorcycleonlinestore.com/search...ducts=avon+roadrider
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 24 May 2010 17:41 by trianglelaguna.
24 May 2010 17:49
Fozzie wrote:
Bias tires are the only type I've ever used. My bike uses tubes and as I understand it from what I've read if you run radial tires with tubes you should use special radial tubes. I certainly have nothing against radial tires, but bias tires work just fine on these bikes. I currently use and am very impressed with the Pirelli Sport Demon (see link.) Ed
Pirelli Sport Demon
Pirelli Sport Demon
