caliper wear
- hocbj23
caliper wear
23 May 2010 09:27
Doing a bit of routine maintenance this AM and in the process decided to mike the calipers.Rear is at 7mm,both fronts at 5mm.Rear caliper is scribed for 6mm minimum thickness before replacement,but fronts have no such marking. I think I read somewhere that fronts limit is 4mm but not sure.Anyone know?Also,when replacement time comes,what is everyone using?OEM Kawi or something else?.Many thanks.bj
- PLUMMEN
Re: caliper wear
23 May 2010 09:43
uh do you mean rotor wear? :laugh:
- hocbj23
Re: caliper wear
23 May 2010 13:05
yeah,sorry-too much of the Irish last evening and im still feelin it.Lol.bj
- PLUMMEN
Re: caliper wear
23 May 2010 14:09
4.5mm for dual disc rotors,if your calipers get down to 5mm youve got bigger problems! :laugh:
- hocbj23
Re: caliper wear
23 May 2010 14:34
i imagine so like ur trying to stop the bike by using a boat anchor-ok that first few feet but when it catches-lol.bj
- hocbj23
Re: caliper wear
23 May 2010 14:37
Plummen-any recommendations on brand?OEM or something else.Looks like Im in for ROTOR replacement at the end of this season.bj
- PLUMMEN
Re: caliper wear
23 May 2010 14:42
ive never had a problem with stock rotors depending on which model you have
- hocbj23
Re: caliper wear
23 May 2010 14:47
82 csr .dual disc up front on LTD wheel and single disc in rear also om ltd wheel.Zuki gs1100e swingarm.I really dont push the bike hard so I think I will just go back stock.The rotors on the bike are the original ones that came on it so I bet im in for fun trying to get them off.oh,well.bj
- PLUMMEN
Re: caliper wear
23 May 2010 15:36
break the bolts loose while the wheels are still on the bike so you can use the brakes to hold the wheels from spinning
- hocbj23
- PLUMMEN
Re: caliper wear
23 May 2010 18:46
sir? im a plumbing/hvac/electrical contractor i work for a living! :laugh: dont thank me,we're all in this together.im pulling for ya!
