Wheel interchange
  • saltydog
  • saltydog's Avatar Topic Author
Wheel interchange
22 May 2010 07:50
#369770
I made a mistake and bought a mag wheel (rear,16") intending to replace the spoked wheel on my 1981 kz1000 CSR. It came without a rear brake rotor. The wheel I bought is apparently for a 1980 or earlier bike. The rotor only uses 4 bolts where my newer one uses 7 bolts. My question is, if I were to find the proper rotor for the older wheel, will it then work on my 1981?
Thanks,
Robert
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
  • TexasKZ
  • TexasKZ's Avatar
Re: Wheel interchange
22 May 2010 08:05
#369777
That bites. If this doesn't work out, I have a complete wheel assembly for an '82 LTD that may be a better fit.
  • saltydog
23 May 2010 07:34
#370085
TexasKZ, Thanks for the offer. I'm not having any luck with my original question. Why don't you pm me and tell me what you want for the wheel?
  • otakar
  • otakar's Avatar
23 May 2010 07:47
#370088
Yes it will, once you get the rotor.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • PLUMMEN
  • PLUMMEN's Avatar
23 May 2010 09:19
#370127
77-80 kz1000 rear rotor should work,i think 750 rear rotor as well as 650 may also work just make sure you have the right spacers for the wire wheel
  • saltydog
25 May 2010 06:08
#370730
I just happen to have a 78 kz650 parts bike. I will have to go check the rear rotor diameter. Thanks for the info.
