Pipe Bridge - What an odd name - Where to find one.
  • skippr76KZ
  • skippr76KZ's Avatar Topic Author
05 Apr 2006 12:08
#36948
Ok. So I was real proud of my front brake line purchase this week. Even bought the correct lines for my 76KZ900LTD. Only problem is I was thinking I was ordering banjo bolt to banjo bolt. Not so, these new lines I bought are the correct fitment that should include the "Pipe Bridge". That metal tube leading from the brake line to the calipers. One of my 2 Pipe bridges are good. Any idea where I can find another? Checked the usual sources, Z1, BikeBarn, Ebay. Found them for the KZ900A4 which is a different part (at least in its shape). Any experience interchanging there? I'd probably pinch the tube, trying to bend it to fit. :S
1976 KZ900LTD Fully Restored
2000 Vulcan FI Classic
1998 Ducati ST2, Gone
  • ltdrider
  • ltdrider's Avatar
Re: Pipe Bridge - What an odd name - Where to find one.
05 Apr 2006 12:25
#36951
Hmmmm.
Seems like it'd be pretty easy to make, just takes the correct fittings, and some 1/8" stainless tubing. I've heard of people filling the tube with sand, then bending it. The sand is supposed to keep the tube from kinking. Never tried it myself, though.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • skippr76KZ
05 Apr 2006 12:37
#36955
LTDRider. Showing me that nice pic of exactly what I need is like teasing a starving dog with a piece of meat. Actually, that sounds like a good idea, only problem, is that I don't have that end piece on the pipe bridge. It was torn off. Also not sure how I would flare out the end of that piping so that there was a correct fit and the end piece wouldn't slide off (if I had it). An undertaking like that - is approaching the limits of my wrenching universe quite probably. :(
  • 77KZ650
  • 77KZ650's Avatar
05 Apr 2006 13:17
#36957
There is a special tool for flaring that type of stuff, I have seen people make brake lines on cars before. it wasnt that hard. About the bending, as long as the bend isnt a very "sharp turn" you can bend them by hand, if you need to go with a small radius on your bend, theres also a tool for that. ask your local mechanic how he makes steel brake lines, he should be able to do it pretty fast or show/tell you how to do it. good luck
Scott
07 MDP Rookie of the Year
  • wireman
  • wireman's Avatar
05 Apr 2006 14:48
#36983
go talk nice to your local auto parts store,they probably will have a bender and flaring tool theyll let you use,if you go in there with a real bewildered look on your face they might even make it for you just take old one with you for a pattern.stainless steel tubing is hard to work with and you need to double flare the ends instead of single flare like regular tubing.or you could stick the line you have with the fittings in that box with the seat and ill make you two new ones and send them with the other seat.:whistle: goodluck,happy wrenching!!
  • TuffyToo
  • TuffyToo's Avatar
05 Apr 2006 15:53
#36997
You may want to try powersportspro.com. They may be able to get what you need. Make sure you order by phone. Ordering on the website doesn't tell you if the part is unavailable.
  • Scotty355
  • Scotty355's Avatar
05 Apr 2006 16:43
#37013
The local auto parts store here sells differant length of brake lines with the ends and flares already on, you just have to bend it to fit, if you take your time and use something to bend it around you can get close.
  • skippr76KZ
05 Apr 2006 17:30
#37033
Excellent feedback guys! Thanks.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
05 Apr 2006 21:23
#37124
I made Mine when I did My dual disk conversion(a couple years ago now).
I bought a double flairing tool...great investment.
I used different sized sockets(in a vice) and a rubber hammer to make the bends...and no kinks.(hooray!)
I DID have to get a machinist to make Me 2 brass inserts(furrows)to seal the connection better,because of the ends of the steel braided lines that I used...the one end had a slight imperfection in it,and it didn't seal completely.
I just grabbed the right sized line from Lordco Auto Parts and chopped it up,to start the project.I used the factory fittings from the old lines,that thread into the calipers.Make sure You slide them on the line BEFORE You flare the ends!LOL(and NO...I didn't screw up and forget to...just thought I'd mention that).
This will be My 3rd season with these lines and no problems at all.
1977 KZ1000 A-1
  • ltdrider
  • ltdrider's Avatar
06 Apr 2006 06:40
#37201
Sorry about the picture, Skip.
Didn't mean to tease you with it, just thought if others could see what you were talking about, it might help.
Greensboro, NC
  • skippr76KZ
06 Apr 2006 11:23
#37244
Sandy, that actually sounds like a fun challenge. It's just that I've got so much to do with this complete rebuild. But I may have to seriously consider your methodology. It obviously works and can be done by a capable person. (key word being "capable") LTDrider, just giving you a hard time. I appreciate the picture you sent. Hopefully, you'll keep looking for the mention of your name. I summon it frequently in the hopes you might weigh-in on one of my LTD specific issues. Things are ramping up. I want to have this finished within a month, )hopefully.....
  • ltdrider
  • ltdrider's Avatar
06 Apr 2006 12:33
#37252
Skipper:
I was looking at your restoration pics. What does your gas tank look like?
I saw a side panel, the paint looks cherry! Is your tank in that good shape also?
Greensboro, NC
