KZ440 LTD
- Sputnic81
KZ440 LTD
05 Apr 2006 10:14
Several people on here have discussed changing their front brakes to a dual disc system. Has anyone ever tried it on a KZ440? If so what kind of system did you use and how did it work out. I have also toyed with the idea of repacing the rear drum with a disc, any ideas on that?
- Sputnic81
Re: KZ440 LTD
05 Apr 2006 10:16
Apparently using the "Back" function in the browser causes problems with new posts. Sorry about that.
- steell
Re: KZ440 LTD
05 Apr 2006 10:27
I have never worked on a 400/440 so I have no idea what will be required to convert it to dual disk, but you may find info at
www.kz400.com
I think the rear drum brake is lighter than the disk and provides more than enough stopping power anyway, so it's not worth converting to a disk.
I deleted the other posts for you
