Another Vulcan shock question
  • apbling
  • apbling's Avatar Topic Author
17 May 2010 06:55
#368489
First off, I want apologize if I am asking a repeat question, but I was not able to find my exact issue on the forum...
So, I have an 82 550 LTD. I go 235ish and the wife is about 120. I still have the stock shocks on the bike. They do ok, but once in a while we'll bottom the shocks out if we hit a large bump.
I'd like to lower the bike a tad, but I am concerned with bottoming out. If I went with a shorter Vulcan 500 shock, would it be a bit stiffer than my current ones to avoid bottoming out? I am starting to think maybe I should just poney up and get the progressive ones, but they sure aren't cheap.
Andy
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: Another Vulcan shock question
17 May 2010 10:29
#368521
I have a couple of pairs of 500 Vulcan shocks mounted on my 650's and I like them. As to the weight carrying capacity I can't say. My best suggestion to you would be to look for a pair from a Vulcan 750/800, they are the same length but have the added features of adjustable dampening and air assist, which I think will give you what you are looking for. They generally sell for a few bucks more on ebay than the 500's do but still much less than the progressives would cost.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
17 May 2010 10:50 - 17 May 2010 10:51
#368526
Whatever shocks are fitted, it's a good idea to assure when bottomed out that tire doesn't hit underside of rear fender, where it will likely obliterate wiring routed underneath the fender.
Good Fortune! :)
Last edit: 17 May 2010 10:51 by Patton.
  • apbling
17 May 2010 13:16
#368546
Do you think the 750/800 would bolt up with no mods? Dare I say could I get a pair of shocks off a different metric bike? I would go with the sporty shocks, but I'd prefer not to mod them too much.
