ZX6R brake and clutch lever perches
- Ituen
- Rider
15 May 2010 02:56
I want to update the brake and clutch levers on my bike. I would like to use ZX6R parts. Does anyone know if there will be an issue swapping 6R brake and clutch lever perches on an older bike?
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- testarossa
Re: ZX6R brake and clutch lever perches
15 May 2010 04:24
The perches themselves should present no problem. ZX-6r clipons are 7/8" just like a normal KZ handlebar. You will have to find a location to mount the brake master cylinder reservoir. On the ZX it should have a small sheetmetal bracket that mounts it to the righthand clipon. Without the bracket to support it, it is just dangling by the small rubber hose between the reservoir and the master cylinder. I am not sure what piston size the ZX master cylinder is. If it is a different size than the KZ MC, then it will change the mechamical advantage of the front brakes. This could lead to either soft brakes with no power, or super hard brakes with no feel.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Old Man Rock
15 May 2010 06:27 - 15 May 2010 06:46
Spiegler custom made brake lines.... Lengths, Colors, Banjo bolts....
spieglerusa.com/cfm/customline.cfm
Bypass the mid line distribution block and use a combo Banjo Bolt brake switch...
Clean installation, less chance of brake pressure leak and color of your choice in line sheathing and banjo bolt anodization....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 15 May 2010 06:46 by Old Man Rock.
- mark1122
- Keep twisting it
15 May 2010 14:48 - 15 May 2010 14:59
i use a zx9/12(same) on mine. they works great, front and rear. way better than the kz brakes.of course i have the bigger, matching rotors as well.
i have the banjo brake light switch as well, u can get 1 at Z1E for about $16.
if u deside to go with the carbon fiber look, black lines with gold fittings, i may have a spare, right front Gaffer.
www.galferusa.com/html/ss_line_kits.html
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 15 May 2010 14:59 by mark1122.
- Ituen
- Rider
16 May 2010 04:56
I will give it a try. Thanks for the info guys!!
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- larrycavan
16 May 2010 06:31
Ituen wrote:
I used zx6 levers on mine. They're awesome with those adjusters for lever position. Finding a non hydraulic clutch lever assembly wasn't easy.
- Old Man Rock
16 May 2010 06:48
Ahhhhhhhhh... Look how purdy that Acewell unit looks there.... :kiss: :laugh: :laugh: :laugh:
Looks killer old man....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
