1979 kz1000 rear brakes
  • bearnekkid
  • bearnekkid's Avatar Topic Author
04 Apr 2006 21:18
#36792
hello ppl finally i found a site that i can relate to
i have a 1979 kz1000 shaft drive with only about 20000 miles but i need parts in the worst way i have been riding with only front brake for the last year does anyone have a pedal return spring pushrod and master cylinder. i am running out of places to search and i figure we classic kz riders need to stay mobile so anyone who can help or needs any parts talk to me
thanx guys be safe ridin'
  • wireman
  • wireman's Avatar
Re: 1979 kz1000 rear brakes
04 Apr 2006 21:24
#36794
is that mastercylinder the same as ltd with a seperate resevoir,or is it all together like 77-78:whistle:
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
04 Apr 2006 22:46
#36802
I'm guessing that it's a seperate set-up,unlike the 77 KZ1000,one piece.I just checked My parts pages,and I also looked on
Buykawasaki.com
but there's no pics for the 79 model...only part desciptions.:huh:
1977 KZ1000 A-1
  • bearnekkid
04 Apr 2006 22:57
#36805
i belive its a seperate resivior i know a 77 wont it up
but ther hasn't been one on there since i bought it
  • donthekawguy
  • donthekawguy's Avatar
05 Apr 2006 05:25
#36843
The 79-80 are different from the earlier models. Not sure about the later ones. Damn if you would have got ahold of me a year ago I had the whole set up I tossedin the trash! :(
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • RonKZ650
  • RonKZ650's Avatar
05 Apr 2006 09:54
#36910
79ST used a master cylinder only used on that bike. I'm sure other master cylinders could be used, but that part # was only used on the 79ST.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
05 Apr 2006 10:04
#36913
Most any rear master should work. Might need a small piece of metal to adapt mounting holes.
  • Duck
  • Duck's Avatar
Re: Rear caliper photo for wireman...
05 Apr 2006 10:08
#36914
Click image for hi-res version.
200
  • bearnekkid
05 Apr 2006 14:18
#36973
i found the rear mastercylinder but still seeking the rod pedal and return spring
seperate note guys thanks alot for all the help i have been looking everywhere for a community like this
  • wireman
  • wireman's Avatar
05 Apr 2006 14:33
#36978
thats the kz style caliper mr.duck.
  • Duck
  • Duck's Avatar
05 Apr 2006 17:10
#37027
Those 42.8mm pistons fit the one in the photo just fine. I thank you mightly! My swing arm and torque bar also look just like your 74, chrome and all. This bike has had some loving in the past. I'm beginning to wonder if it is stock 1015cc or not.
Sorry for hijacking thread. You may be able to use a piece of steel rod with the end ground and a spring from the hardware store. I can probably scare you up a rod from the scrap bin.
How long does it need to be? Suspect diameter is about the same and not critical for all these rear brakes.
-Duck
