320mm oversized rotors
11 May 2010 18:22 #367329 by ELCouz
320mm oversized rotors was created by ELCouz
Hi,
I have ordered calipers (with custom bracket) that fit only 320mm rotors.
Is somebody aware where i could get oversized rotors for my gpz 750 1982?
Have a nice day!
Thanks,
Laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
11 May 2010 19:31 #367344 by MFolks
Replied by MFolks on topic 320mm oversized rotors
12 May 2010 05:19 #367398 by The Fish
Replied by The Fish on topic 320mm oversized rotors
Your best bet would be from the place that you got the calipers and brackets from.
I would imagine that they would also sell the discs to use with their oversize brake kits.
Here's one of mine
6 pistons, 310mm discs, 76 KZ 900
12 May 2010 06:20 - 12 May 2010 06:22 #367401 by otakar
Replied by otakar on topic 320mm oversized rotors
I Have a similar problem but at a different point. I need the mounting plates that adapt one type of caliper to the fork mount. Anyone know who has a selection of those, before I start cutting my own. I am trying to adapt zr750 calipers to "J" forks with ST oversize rotors. I need to move the calipers farther out and up and the bolt spread is a bit larger. something almost the same if NOT the same as in the preceding picture.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 12 May 2010 06:22 by otakar.
  • trianglelaguna
12 May 2010 09:55 #367444 by trianglelaguna
Replied by trianglelaguna on topic 320mm oversized rotors
No eBay APP ID and/or Cert ID defined in Kunena configurationouch
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • hocbj23
  • Visitor
12 May 2010 13:40 #367481 by hocbj23
Replied by hocbj23 on topic 320mm oversized rotors
Makes ya wish that Sandy Klaus came early this tear doesnt it.bj
12 May 2010 13:58 #367488 by School Teacher
Replied by School Teacher on topic 320mm oversized rotors
gsxr 1000 2001-02 are 320mm
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
12 May 2010 14:43 #367506 by The Fish
It would probably be wisest to get the disc from the person that you got the "kit" from.
There are a lot of mfg's that have 320mm discs. Most of them have different offsets than the others and "stumbling" across an exact fitting disc would be "wishful thinking".
I haven't found a bolt on 4 bolt brake disc in 320mm that will bolt directly on to the KZ wheel. The discs usually need to be modified to fit the application that I am putting them on.
I believe that EBC will custom make a disc for you.
13 May 2010 14:42 #367709 by ELCouz
Replied by ELCouz on topic 320mm oversized rotors
I've bought the calipers from a kawa Z1000 2005 which are Nissin and are for 320 mm rotors.
My original calipers are FUBAR (cracked).
Since i have access to a waterjet cutting machine i'll be designing my own brackets.
That's why i'm asking where you get these rotors?
Kind Regards,
Laurent
14 May 2010 04:26 #367838 by The Fish
I get the discs where ever I can (ebay, swap meets, yard sales) and I often buy them brand new.
It would probably be best to get some custom made discs through EBC. Most motorcycle shops can get them.
When I get discs for my kits, what they are and what they fit doesn't really matter much. What matters the most is " Can I modify them to fit what I am working on ?". All of my kits come with modified discs(discs that were modified to fit a particular application and will ONLY fit that particular application).
I am not aware of a bolt on 320mm disc for the KZ wheel. Custom made may be your only option. There are very few 4 bolt brake disc made for the KZ and they are usually OEM style replacements(Stock size).
14 May 2010 08:43 #367877 by PLUMMEN
Replied by PLUMMEN on topic 320mm oversized rotors
ive got a machinist who offered to make some billet front hubs that will use stock bearings and spokes,but i need to figure out which rotors to use for him to make mounting holes for them.
are there any big rotors with offset close to stock kz rotors? B)
14 May 2010 15:28 #367953 by The Fish
JMO,
If you are custom making a hub, you can have it made to work with any brake disc you want.
Another JMO,
If you are making a hub, I can't see the advantage of making a (dimensionally) identical hub to one that is already offered (stock KZ). Custom make a hub to work with a disc and factor in the (disc)offset in the fabrication of the hub.
The old (KZ) discs are what are considered wide band rotors. They use the height of the brake pad to contact the "wide band" of the rotors. The newer discs are considered narrow band rotors. The use the width (front to rear)of the brake pads to contact the rotor.
Using a narrow band disc(newer disc) with a wide band (stock KZ) caliper usually have the brake pad contacting the buttons on the rotors. I would strongly advise against cutting the brake pads for clearance (they may contact the buttons when the pad wears down). I have seen 1 person do it on the CB 750 message board, and(a 3rd JMO) is a disaster waiting to happen.
