Rearsets
- hocbj23
Re: Rearsets
12 May 2010 14:00
yep.Thanks. I just snuck a bid in on the shifter.I would appreciate a pic or so on both sides so I can estimate where the mounting holes should go. I happen to have an extra set of brackets so if I screw up, I can always use the 2nd set.bj
- hocbj23
Re: Rearsets
26 May 2010 11:02
Ok.I got the footpeg relocated to the rear and the 1100 shifter linkage connected up (after some trimmin and shimmin-lol).Only problem is that I have some slop in the linkage and have trouble engaging neutral,I notice that the linkage is adjustable,but I dont have an 1100 manual to advise on how to adjust.Any thoughts?Thanks.bj
- hocbj23
- porchev914
Re: Rearsets
27 May 2010 18:50
Can you identify the source of the slop? Is it at the rod/heim joint connection, the heim joint/pedal connection or the heim joint/ shift shaft connection? Find the source and we'll be able to help you out bud.
FRANKEN Z!
- hocbj23
Re: Rearsets
30 May 2010 19:07
seems to be at the Heim joint pedal AND shifter armconnections--like maybe the joints are worn.Since this is used part,that probably is true,but not sure if they can be tightened up in some way.thanks.bj
