Sidewinder kickstart fabrication?
- boogy699
06 May 2010 22:14
I have a sidewinder and I have 11 to 1 compression. Does anyone know how to fab a kickstarter or buy one.
- Old Man Rock
Re: Sidewinder kickstart fabrication?
07 May 2010 04:52
Someone may have an answer/solution for ya but would kind of help if we new year and model you're speaking of....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- zed1015
07 May 2010 05:31 - 07 May 2010 10:04
Heat up and bend the original one to the required shape then weld in a gusset to resist bending and twisting.
Here's one i did earlier to miss my rearsets which was then powder coated black.
Last edit: 07 May 2010 10:04 by zed1015.
- Kraz1
07 May 2010 07:31
Old Man Rock wrote:
OMR, Jason has a '78 KZ1000...
Take another splined section from a second Kickstarter arm, and weld it onto your existing Kickstarter Arm. This should step you out far enough without having to put a bend in your Kickstarter. I couldn't find the Arm I have here to show you, but you get the idea,
OMR
- PLUMMEN
07 May 2010 07:44
put a honda starter and a good battery in it
- Kraz1
07 May 2010 08:05Please Log in or Create an account to join the conversation.
- zed1015
07 May 2010 10:03 - 07 May 2010 10:06
You could also try the stronger, heavy duty J or GPZ11 starter as they are a straight bolt in swop and use four commutator brushes instead of the earlier 1000's two.
Last edit: 07 May 2010 10:06 by zed1015.
- PLUMMEN
07 May 2010 14:59
zed1015 wrote:
i didnt know thatYou could also try the stronger, heavy duty J or GPZ11 starter as they are a straight bolt in swop and use four commutator brushes instead of the earlier 1000's two.
- zed1015
08 May 2010 04:04
PLUMMEN wrote:
Yes , Any of the later J style engines (1980-ish and on) with no kickstart shaft use heavier duty four brush motors.
zed1015 wrote:i didnt know thatYou could also try the stronger, heavy duty J or GPZ11 starter as they are a straight bolt in swop and use four commutator brushes instead of the earlier 1000's two.
