79 Kz1000 singarm question
  • smoothnf
  • smoothnf's Avatar Topic Author
03 Apr 2006 23:42
#36590
Is the 77 Kz1000 swingarm is same as the 79 KZ1000 LTD swingarm...What i want to know is. Will it work without any modication....Thanks
  • wireman
  • wireman's Avatar
Re: 79 Kz1000 singarm question
03 Apr 2006 23:47
#36591
the swingarm should be the same,the brake caliper is differant on ltd but will still fit.;) goodluck,happy wrenching!
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
04 Apr 2006 14:30
#36605
Don't we know it ;-)
  • wireman
  • wireman's Avatar
04 Apr 2006 15:04
#36613
duck,check your pm:whistle:
  • RonKZ650
  • RonKZ650's Avatar
04 Apr 2006 19:42
#36756
If it's a KZ1000A vs a 1979 LTD, no they are not the same. Kawasaki didn't use A parts on a LTD ever. Length will probably be different and for sure LTD chrome chainguard which is crap will not mount to the plastic chainguard mounts on a 1977 KZ1000A.
  • wireman
  • wireman's Avatar
04 Apr 2006 19:48
#36760
yeah the chaingaurd mounts might be differant ,but im sure the lengh and width should be pretty close.
  • wireman
  • wireman's Avatar
04 Apr 2006 19:56
#36766
i just got to thinking my dad bought the red 78a2 ive got in spring of 79,it came with a chrome steel chaingaurd,not the plasic one that swingarm also has an extra mount on the chain side i never figured out what it goes to though.;)
  • zkrobz
  • zkrobz's Avatar
06 Apr 2006 13:33
#37273
As far as I know The only real difference is that the 1979 swingarm will have 2 bearing on each side and the 1977 will only have one so when doing the conversion make sure you use the swingarm bolt from the 1979. It has a wider machined area.
