Chain tension changes
  • Digitlghost
  • Digitlghost's Avatar Topic Author
05 May 2010 12:57
#365747
I recently put new tires on an 82 KZ750 LTD that we are trying to revive. When trying to adjust the chain tension we noticed that the chain will go from slack to tight as we roll the rear wheel. Is this something to worry about? If so, what are likely culprits (bent sprocket shaft, warped sprocket, etc.)?
  • Capt America
  • Capt America's Avatar
  • Born Bad
Re: Chain tension changes
05 May 2010 13:16
#365749
Sounds like a bad chain, ceased links in a chain will do that. If the sprockets look good, I'd slowly roll the wheel with bike on center stand (if it's still got it) and watch the bottom chain run for kinks in the links.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 May 2010 13:22
#365751
it is fairly common to get a stretched section in the chain.
u will want to adjust to the loose section.if its bad,it will slap on the guard or arm. its time for a new chain and sprockets.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Digitlghost
05 May 2010 13:25
#365754
Thanks much, I'll check the chain for kinks.
  • Kawickrice
  • Kawickrice's Avatar
05 May 2010 13:29
#365757
Yep classic signs of the chain getting worn, could be warped sprockets too. X2 on replacing chain and sprockets
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • bountyhunter
  • bountyhunter's Avatar
05 May 2010 14:29 - 05 May 2010 14:30
#365777
That is the absolutely classic symptom of a worn out chain... the good news is Z1 has the best prices on good X-ring chain.
Last edit: 05 May 2010 14:30 by bountyhunter.
  • Digitlghost
10 May 2010 07:17
#366987
Ok so I'm going to replace the sprockets and chain. I would like to convert to a 530 chain. I was wondering if anyone knows the default sprocket size and chain length for the 82 KZ750 LTD?
  • otakar
  • otakar's Avatar
10 May 2010 07:21
#366989
Call Z1E and they will do the entire conversion for you.They have a program that figures all that out.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
