tires size
  • catahe
  • catahe's Avatar Topic Author
tires size
04 May 2010 15:34
#365518
HELLO GUYS I HAVE A 1978 KZ1000 Z1R JAPANESE VERSION WITH TIRE SIZE 3.50 18 FRONT AND 4.00 18 REAR. WHAT METRIC SIZE SHOULD I USE IN ORDER TO BE EXACTLY THE STOCK MEASURE, IM ALMOST CERTAIN A HAVE TO GO FOR 100 AT THE FRONT BUT DO I GO FOR 110 OR 120 IN THE REAR. WHATS BETTER? PLEASE ADVICE THANKS
  • otakar
  • otakar's Avatar
Re: tires size
04 May 2010 18:48 - 04 May 2010 18:50
#365566
100-90-18 front 110-90-rear will give you the exact sizes. In front you may substitute.
90-90-18 or 110-80-18
in the rear you may substitute
120-90-18 0r 130-80-18
You may refer to the following thread that covers exactly that subject.
kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=365224
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 04 May 2010 18:50 by otakar.
  • RonKZ650
  • RonKZ650's Avatar
Re: tires size
04 May 2010 20:29
#365622
You won't get an exact size in a metric tire. That's like asking what size metric socket is exactly the same as a 1/2". A 13mm is close, but not exact. If you want exact get the 3.50 and 4.00. If you want metric tires that work you can do this. Get a 100/90-18 front. It will be a little smaller diameter as well as less width than original, or you can get a 110/90-18. It will be a little wider and larger diameter than original. On the rear you can get a 110/90-18 but it will be much smaller diameter than the original size although width will be close, or you can get a 120/90-18 and the tire will be too wide but the correct basic diameter. So there you go, that's the choices in metric to be "exact". Look for manufacturers that support inch size tires and support those companies. Metzler, Avon, continental among others offer correct tires, but few companies carry them. If you must a 100/90-18 is "OK", a 120/90-18 is "OK", but not exact.
  • catahe
Re: tires size
04 May 2010 20:34
#365624
thanks ron i want to g o for the stock ones,in what brand or where do i find the 3.50 and the 4.00
  • otakar
  • otakar's Avatar
Re: tires size
04 May 2010 23:09 - 04 May 2010 23:10
#365641
If you go on the Avon web sight they give you the exact sizes. in both metric and inch. The tire sizes i gave you are measured from those graphs and are with in a few mm of the inch sizes. Check it out for your self. They also have the tires in the inch sizes.
www.avon-tyres.co.uk/motorcycle/
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 May 2010 23:10 by otakar.
