Fork guide bushings
  • hocbj23
  • hocbj23's Avatar Topic Author
Fork guide bushings
30 Apr 2010 18:43
#364562
So the 82 kz1000 is weeping oil from the fork oil seals and I tear the forks down today to replace.When I get the forks apart, the teflon is smack worn off the upper and lower guide bushings.So I hoof it over to the local Kawi dealer and we go thru the microfiche. Wonder of wonders-the upper guide bushing is available for 12 pesadas a copy, but no mention of the lower even though I am holding it in my hand.We search several other sources-no lower guide bushing. My only thought is that Kawi realizes that if u wear out the lower bushing,you will soon wear out the lower fork tube and they are $416 dollars each. Holy Manuto.So I got worn out lower guide bushings and cant seem to find any. Any help from anyone on a source?Thanks much.bj
  • 893cv
  • 893cv's Avatar
Re: Fork guide bushings
30 Apr 2010 19:51
#364590
Try Racetech.com , they have lots of these parts, and their stuff is very good quality too.
1980 kz1000 LTD
1978 Z1R
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
01 May 2010 01:42
#364641
Yeah, I think they were sold as part of a set by Mother Kaw (bundled with the inner fork tube, etc.)...you might be able to get help from a KZR member if you had the model of your bike posted (Kawasaki released 5 different KZ1000 models in 1982). If not, then you might be forced to gamble on eBay...where all things appear for sale, eventually.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • hocbj23
01 May 2010 06:54
#364672
according to serial number it is a Japanese built "K" model.I think same forks were used on both K and M models however.The forks are factory 38mm with a leading axle configuration- a cruiser bike set-up.Thanks for the assistance.bj
