Popping into 2nd from 3rd gear - '78 KZ1000 B2
- jtate1000
30 Apr 2010 11:48
Hey guys,
Pretty much as the subject describes- my KZ1000 will drop into 2nd from 3rd gear while cruising at moderate "in-town" speeds. All other gears are fine. It shifts fine up and down through all 5 gears. I'm not well versed on the drivetrain so any ideas are welcome.
- PLUMMEN
Re: Popping into 2nd from 3rd gear - '78 KZ1000 B2
30 Apr 2010 12:26
check the shifter linkage /lobster claw under output shaft cover and trap door,maybe spring going bad?
- jtate1000
03 May 2010 07:04
I will definitely check that out. I'm curious though, if that was the issue would it not cause the problem between all gears?
- jtate1000
06 May 2010 08:30
*Bump
Just wondering if anyone else might have any ideas for my bike's issue. I'm probably going to start looking at it this weekend so thought it'd be good to have 2 or 3 possible things to check out. Thanks!
