Best way to clean rust from exhaust?
  • Glitch
  • Glitch's Avatar
Re: Best way to clean rust from exhaust?
27 Apr 2010 19:58
#363728
You could use Electrolysis. Removes only rust the rest of the metal is left intact. all you need is baking soda battery charger some steel or iron sheeting and your battery charger. I've done it in the bathtub before, much to the chagrin of my room mate at the time. Where else was i supposed to put a full exhaust system without taking it appart?
users.eastlink.ca/~pspencer/nsaeta/electrolysis.html
-Glitch
1982 Kz750 h3 ltd
  • PLUMMEN
  • PLUMMEN's Avatar
27 Apr 2010 20:09
#363733
find your local welding shop and see if hes got some stuff waiting to be blasted till he gets a bigger load of stuff todo ,sometimes you can get stuff done cheap that way
  • Tony
  • Tony's Avatar
    Author
27 Apr 2010 20:25
#363745
I've used naval jelly in the past and it works great.
  • T_Dub
  • T_Dub's Avatar Topic Author
28 Apr 2010 04:56
#363786
Cool, I might go the chemical route, that'll be cool.
Otto, did I see you say that most grout remover is phosphoric acid?
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
28 Apr 2010 06:07
#363797
Glitch wrote:
You could use Electrolysis. Removes only rust the rest of the metal is left intact. all you need is baking soda battery charger some steel or iron sheeting and your battery charger. I've done it in the bathtub before, much to the chagrin of my room mate at the time. Where else was i supposed to put a full exhaust system without taking it appart?....
Excellent suggestion imo. :cheer:
Also works for removing rust inside fuel tanks (no immersion involved).
For exhaust, instead of bathtub, consider an appropriate sized plastic trash can, with a liner to assure against leaks.
Like Otakar, I've had success by brushing with muratic acid. Outside of course. Being very careful. Wearing goggles, rubber gloves, clothing without exposed skin. Not splashing acid around. Don't breath the fumes.
When acid has finished its work, rinse with water hose.
Am also wondering if feasible to have the exhaust system "boiled" at radiator shop? :unsure:
Good Fortune! :)
  • otakar
  • otakar's Avatar
28 Apr 2010 10:04 - 28 Apr 2010 10:11
#363838
The Phosphoric acid I use is called "Rust Mort" I bought it at an Automotive paint supply in a quart bottle. You can go to the hardware store and see if anting else is Phosphoric acid. But I know that the "rust Mort is designed specifically for the purpose of stopping rust and I do not want to start outguessing the Chemists. For the electrical rust removal,which by the way works quite well, it is not Baking soda that you use it is "Washing Soda" AKA "Soda Ash" Sodium Carbonate (Na2CO3). this product is also sold by Arm & Hammer. It is product #WS-03020-02 and it is called "Super Washing Soda"
en.wikipedia.org/wiki/Sodium_carbonate
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 28 Apr 2010 10:11 by otakar.
28 Apr 2010 10:27 - 28 Apr 2010 10:33
#363842
Once upon a time there was a KZr member who always checked an image for acceptable format before attempting to post. :S :laugh:
Last edit: 28 Apr 2010 10:33 by Patton.
28 Apr 2010 10:29
#363843
  • kzmk2
  • kzmk2's Avatar
28 Apr 2010 10:36
#363844
I have found that monument companies (grave markers)do sandblasting for a reasonable price. The ones I dealt with would blast once per week and do an exhaust system for about 20 bucks.
  • RaeRae
  • RaeRae's Avatar
  • Smart @ss white girl!
28 Apr 2010 13:24
#363880
After sanding, we used some sort of jelly checmical on both my tank and now the headers which were heavily rusted!! I can look at the bottle later to get the name of it if you need....WORKED like a charm!
Tank
Headers
Goodbye rust, waiting for the VHT fireproof primer and VHT fireproof flat red paint!
Gonna look tight! B) :woohoo:
Best of luck!
Rae ;)
OWN:
82 KZ550 LTD (work in progress)
81 550 GPz (work in progress)
81 KZ550A (parts bike)
91 750 Honda Nighthawk
WANT:
One in every size and color! =)
Euharlee, GA by way of Glendale, AZ
  • otakar
  • otakar's Avatar
28 Apr 2010 13:34
#363882
I used VHT on my headers last year. I first primed them and than painted them black. That lasted about 2 rides. This year I am going to have them Ceramic coated and it will last for ever.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • RaeRae
  • RaeRae's Avatar
28 Apr 2010 13:43
#363884
Really Otto? What happened with it?
What went wrong you think? I've heard good things about the VHT fireproof paint as long as you "cure" it properly?
:huh: Rae
OWN:
WANT:
