USD Forks
- pannycj
USD Forks
25 Apr 2010 16:59
Hi guys, I know this has been a topic on here a ton of times but i'm relatively new to the site and am having a hard time finding solid answers on swapping a '93 Suzuki GSXR 750 inverted forks over to my '77 KZ 1000. I want to have everything figured out before I tear the front end off the bike and have nothing to ride. I was told welding the Kz stem and the GSXR stem together is an option. Do I use the stock kz neck bearings with this set up? What have others done?
THANKS!
THANKS!
Chris Panny
CP Performance Fabrication
Rochester NY
Rochester NY
- thompsonmx100
Re: USD Forks
25 Apr 2010 19:05
Do some research. You will probably have to press the stem out of the gsxr triples and install the kz stem into the gsxr triples. then you can use the bearings from a kz.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- testarossa
Re: USD Forks
25 Apr 2010 19:22
+1 on what thompsonmx100 says. I'm doing this on my bike with '95 GSXR forks (same as '93) and a '78 KZ1000. Look for Testarossa's fighter build thread. I have lots of pictures and fairly detailed instructions on everything that I have done so far. I'll be happy to explain anything that doesn't make sense or whatever. Also, mark1122, OldManRock, porchev914, and others have done similar swaps. It's really not that hard once you get it all figured out.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
Re: USD Forks
25 Apr 2010 21:17
Here ya go Panny, this guy was asking the same question, and Old Man Rock posted a link to a PDF he created about his front end swap. I really can't be included in testarossa's list, I am going the cop out route and having a fellow KZR member make me some custom triple clamps. I WAS going to chop the donor stem flush with the bottom triple, chuck it in a lathe and turn the i.d. to match the o.d of the Kz stem. Push the Kz stem into the donor stem/bushing, then weld stem to bushing. Install new bearing and viola! New front end. There are other considerations like steering radius limitations and lighting mounting and others I'm sure. But that is the dirty basics, or at least one way to do it.
kzrider.com/index.php?option=com_kunena&...d=5&id=352040#352051
FRANKEN Z!
- pannycj
Re: USD Forks
26 Apr 2010 10:55
Awsome guys. Thanks!
Chris Panny
Rochester NY
Rochester NY
