Front Fork Tube springs 1975 Z1 900
- ed spangler
- Tennessee Z
25 Apr 2010 07:47
Good Morning
I dissambled the front forks yesterday on my 1975 Kawasaki Z1 900, I noticed that one end of the inner fork springs that fit inside the tubes was compressed for about 6-8", in order words the coils are actually touching on one end of the springs..
I assume that is by design, however I am unsure if this compressed portion of the spring should be on the upper or lower end of fork tubes??
Hope this makes sense.
Could use some input on this please.
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
- otakar
Re: Front Fork Tube springs 1975 Z1 900
25 Apr 2010 08:55
In reality this makes no difference. This is what is known as a dual rate spring. Supposedly if you place the more dense section to the top there will be less fork noise. I have never been able to tell the difference. I always place mine with the more dense section to the bottom. The denser the section is the quicker it reacts (the softer it is everything els being equal). This being said this means that the denser section moves more frequently. Since this being a fact, i want to keep this section in oil at all times, the upper section (less dense) of the spring being dry.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Mcdroid
- Gone Kwackers
25 Apr 2010 08:59
Otto may be correct, just as long as you do the same orientation for both forks. I thought I had read a recommendation some time ago and I have looked through all my Kawasaki manuals and it just doesn't specify :blink:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- ed spangler
- Tennessee Z
25 Apr 2010 10:43
Thanks!!
- ed spangler
- Tennessee Z
25 Apr 2010 10:45
Hey!!
Thanks
Yeah, I looked at the Clymers Manual I Have and another manual. No mention.
Thanks Again
ED
Thanks
Thanks Again
ED
- mark1122
- Keep twisting it
25 Apr 2010 15:01
while your in there u could add a 2" spacer made of ABS( or what ever u can find), to the top of the spring.
This will help decrease front end dive and firm it up a bit. if u dont like the feel just remove them, no harm done.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- ed spangler
- Tennessee Z
26 Apr 2010 02:01
Thanks
