KZ650B1 vs. KZ650E1 (KZ650 LTD)
  • 80sDweeb
  • 80sDweeb's Avatar Topic Author
21 Apr 2010 23:35
#362254
Can anyone tell me if the frames are basically the same between a 1977 KZ650 and a 1980 KZ650 LTD? The LTD doesn't have the "duck tail", and has a smaller (16"?) mag rear wheel (still drum brakes) and the tank has a little bit different shape (a little bit coffin-shaped, I'd say.) I'd love it if the tank, seat, and ducktail from a '77 would drop right onto the LTD frame, along with the spoke 18" rear wheel. Will they?
It's been a while since I "lived and breathed" KZ650s, so my memory on these details has faded...
Scott in Penfield NY
  • djturnz
  • djturnz's Avatar
Re: KZ650B1 vs. KZ650E1 (KZ650 LTD)
22 Apr 2010 04:24
#362265
IIRC there is slightly more rake in the neck to accomidate for the longer forks. I would think the backbone is the same though.
1982 KZ750 (4) LTD
  • anarki650
  • anarki650's Avatar
22 Apr 2010 14:49
#362433
Only part of those frames that will be identical are the motor mount areas...The rake is different, the spine and tank mounts are different, and the rear is completely different, nowhere to mount the duckbill and the seat mounts plus brake system mounts will be different because of the different wheel sizes...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
