KZ650- 78 Gas tank on a 79? Please Help
- Beard
19 Apr 2010 07:03 - 19 Apr 2010 11:28
So I get my first bike and have my permit.. I want to get out and ride but the holes in my gas tank are preventing that. The largest hole is pretty big. (size of a thumb) not sure how brazing will do.. then the tank is lined already. just alot of hassle.
Does anyone know if a 78 tank will work on a 79b3?
any changes in mouting sizes or petcock?
If you can give me some direction I would greatly appreicate it.
Thanks
Adam
Thanks
Adam
79 KZ650B
Jack of everything, Master of nothing.
Last edit: 19 Apr 2010 11:28 by Beard.
- Mcdroid
- Gone Kwackers
Re: 78 Gas tank on a 79? Please Help
19 Apr 2010 09:29
Hello Adam...
www.kawasaki.com
shows the tanks and petcocks as interchangeable. Perhaps a 750 twin owner can confirm this?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- saxjonz
- KawboyZ
19 Apr 2010 09:53
B3 LTD 1000? All of the 900-1000 tanks will work on that model. I believe the 76 tank would require some retrofitting to the tank as they had a vacuum feed which would require the use of an adapter plate that pingel sells. Just make sure your tank supports on the frame are where they need to be toward the back and that they do not slip around or the tank will slide back and forth.
As long as you have that bung-hole you're good to go. :blink: To avoid further hassle with the petcock if it is leaky replace it with a pingel unit. Expensive but for me worth every penny not having to monkey around with those leaky petcocks. Good luck on that. Sounds like you have or will have other issues to iron out. It is never just one thing with these bikes. Never. But well worth it when you finally get them sorted out.
79 LTD B3
- trianglelaguna
19 Apr 2010 10:20
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- JMKZHI
19 Apr 2010 10:39
It's helpful to mention what size the bike is.
- Beard
19 Apr 2010 11:29 - 19 Apr 2010 11:37
crud....
sorry i was in a panic..
1st post.. complete idiot.. nicely done.
kz650
kz650
79 KZ650B
Last edit: 19 Apr 2010 11:37 by Beard.
- Kawickrice
19 Apr 2010 11:37
It says KZ650 in the heading. I have a 77B1 tank on a 79D3 frame. It should work. I have used epoxy puddy to fix holes before in tanks before with no leaks.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Beard
19 Apr 2010 11:38
heading - it says it now
79 KZ650B
- Bluemeanie
19 Apr 2010 20:09
Tanks are interchangable between 77-80 KZ650's. The CSR or LTD tanks do not work on KZ's.
