air assisted fork to non air fork conversion
- Glitch
18 Apr 2010 17:51
Okay it's official I'm all googled out. I've got a 1982 Kz750 ltd with air pre-load front forks. I'd like to convert them to spring only with a set of progressive springs, since it's more reliable and one sides seal is leaking. I saw several references to doing this at some point but no in-depth information on how it might be done. Does anyone have a link or is it even worth the time, or should i simply replace the oil seal and live with the tempermental air assist?
Thanks for your time and help.
Glitch
Glitch
1982 Kz750 h3 ltd
- TeK9iNe
- What did you do!?!
Re: air assisted fork to non air fork conversion
18 Apr 2010 18:06
Glitch wrote:
Why not just rebuild them properly. Air assist works fine and has been used forever.
If it keeps the oil in, it keeps the air in.
If your worried about one leaking down/unsafe change, then get an air balancer. It connects across the two air fill nipples and balances the air between them automatically.
Glitch
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Tony
Author
18 Apr 2010 19:35
I had air assist on my mk2 and it worked fine. But it leaked down after a couple weeks. In the end I put in progressive springs in and swapped the fork caps from my 76 kz750 to the mk2 and put the air assist on the 750.(They have the same forks)
That's how it's been for quite a while now, no problem.
- thompsonmx100
18 Apr 2010 21:04
I too would like to get rid of my air assist. I dont like the look of it on the front forks. So i would like to find out if there is a way to convert the forks. Is there anything special about the forks? or could you just weld up the hole and put good springs in them?
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- polkat
18 Apr 2010 22:09
I messed with this for a while (I have the same bike) by making slightly longer shims (under the caps) which increased the spring rate, then just plugging the caps. Worked 'okay' but not great, so I went back to air assist. Changing out the seals is easy and cheaper then new springs, and it's pretty easy to make your own air balancer, which is simply a hose between the fittings with an air valve T fitting in between. You only have to put air in a single valve and it's balanced.
- H1Vindicator
Last edit: 20 Feb 2013 20:08 by H1Vindicator.
- otakar
19 Apr 2010 08:09
H1Vindicator wrote:
+1 I also put in a old set of valve springs on top of the original springs. This helped to take up the loss of the air pressure.
Uh, I believe it's simple.
Just put in some new progressive springs & eschew the air.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Apr 2010 08:20
I have a set of Progressive springs that I never used if you are interested. They are 11-1111 that have a higher preload and will not require any air.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- polkat
19 Apr 2010 11:53
otakar, interesting idea with the valve springs! What springs did you use, and did you use the spacer? Was it hard to get the cap back on? When I made the longer spacers it worked okay, but the forks would bottom out sometimes.
- otakar
19 Apr 2010 12:33 - 19 Apr 2010 14:18
I just used a set of old 750 valve springs. I used the entire inner and outer spring assembly.I put a washer in between them so the inner spring would stay in place and the existing washer on top. I took a deep well socket and made a tool out of it which I use with a "T" handle and it makes it quite simple to install the cap.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 Apr 2010 14:18 by otakar.
- polkat
19 Apr 2010 14:13
Glitch, not trying to steal your post. One more question and I'll back off. otakar, so you left out the stock long sleeve...right?
- otakar
19 Apr 2010 14:17
What ever is in there you leave in there. You just add the spring. You will have to find a spring that fits your application due to the fact that different forks have different IDs. As I mentioned, I do have a set of New Extra Progressive springs if you cant make a go of this mod.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
