Center Stand Hitting Chain-'78 KZ1000 Ltd.
- jtate1000
15 Apr 2010 11:25
Hey guys,
On my '78 KZ1000 Ltd, the center stand does not have some sort of stop that keeps it from retracting into the chain. The chain is adjusted properly. The PO had the stand off when I bought it- he just had the center stand, two bolts, and spring. What am I missing? I can't find a diagram and/or any good enough pics to see for myself. Thanks in advance!
- trianglelaguna
Re: Center Stand Hitting Chain-'78 KZ1000 Ltd.
15 Apr 2010 12:16 - 15 Apr 2010 14:13
what kind of pipes are you running...if not stock then it may be the stock pipes had a stop for the stand to not bounce..in which case you can fab one...
my 900 has a 4 into 1 header...
so my buddy sent me one of the ones he had special made to go on the inside of the passenger peg bolts
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 15 Apr 2010 14:13 by trianglelaguna.
- The Gringo
- ¡Usted no necesita otra motocicleta!
15 Apr 2010 13:36
The LTD's from that era did not come with a center stand. The stock Jardine pipes were never set up to run with one. Your best bet is to just keep the stand in the garage and use it when you want to do any service work on the bike.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- asevans
16 Apr 2010 19:39
go to the hardware store and get some aluminum bar stock or something similar. drill a hole in one side and half moon on the other. just like int he pick above. paint it black. you will have to bend it to fit. put it on a vise or something. ive got mine mounted on the right side on the inside of the exhaust mount and you cant even see it.
1976 kz900 Mostly stock
1978 Z1-R Project
1978 Z1-R Project
- Gman
17 Apr 2010 06:55
This one is on my '75 with a 4-1 Kerker. It's not as purdy as the one Trianglelaguna has but it works well.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
17 Apr 2010 08:12
Gman wrote:
Might also consider expanding bracket to this area for less risk of loosening and getting out of position while riding.
[Click on image to enhance view.]
- rstnick
17 Apr 2010 14:14
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
