Tires -- tube rims w/ latest style tubeless tires
  • circusnuts
  • circusnuts's Avatar Topic Author
13 Apr 2010 21:47
#360525
Will it work & is it recommended? I just do not know a lot about this stuff.
Thanks!
Phil
  • JMKZHI
  • JMKZHI's Avatar
Re: Tires -- tube rims w/ latest style tubeless tires
14 Apr 2010 07:20 - 14 Apr 2010 16:28
#360580
Edit: I think I misunderstood.
But I'll go ahead & say you can use a tube in a tubeless tire.
I put GT501s w tubes on my 81 CSR.
Last edit: 14 Apr 2010 16:28 by JMKZHI.
14 Apr 2010 09:54
#360615
Thanks!
Phil
Depends on what you mean by "latest style." Do not use radial tires with tubes. Other tubeless tires work fine. Here's what I use on my KZ650C1 (with Metzeler tubes as recommended by Pirelli):
Pirelli
  • jeffasaki
  • jeffasaki's Avatar
14 Apr 2010 10:03
#360618
If your gonna run tubless on old mags like Kawasaki made for the Z1Rs that where intended to use tubes.Give the inside of the rim a coat of paint.Some of the old castings are a little pouros and will slowly leak air
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
