Struts or shocks?
- boogy699
Struts or shocks?
13 Apr 2010 15:25
I have a 78 kz1000 that is too low to the ground. I was wondering if anyone knew of any other bikes or aftermarkets that will bolt right up to raise it or should I put some struts in?
Re: Struts or shocks?
13 Apr 2010 15:57
I suggest you remove 1 shock and measure it eye-to-eye. It's possible the previous owner replaced the shocks with something short to lower it. Post the length of the shock after measuring and I'm sure folks on this site can tell you what shocks will correct the ride height. I wouldn't put struts on it if you plan to actually ride it
- Bad Dad
13 Apr 2010 16:15
650ed wrote:
Yeah, unless your like 6'6", I can't see needing "longer" than stock shocks... but you can find longer shocks, if you need them!
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
