82 kz250 Front Fork Dust seals/boots
- morhaven
13 Apr 2010 04:42
Hi guys I need to replace my fork dust boot for 82 kz250 .
Z1 enterprise does not have any..
I am hoping you can help me with where i can locate these.
I see some on ebay but they don't look the same?
can any other model bike fit? like the 650 boots?
thanks
thanks
- Motor Head
Re: 82 kz250 Front Fork Dust seals/boots
13 Apr 2010 05:00
92049-1080 is the inner oil seals,
92093-1066 is the outer dust boots.
My local dealer lists them, so does the other Bike web sites I use.
Try These numbers in your search at cyclepartsnation.com
or cheapcycleparts.com
- JMKZHI
13 Apr 2010 08:52
If they are available at the dealer, Z1Enterprises.com should be able to get them. Contact them.
- Mcdroid
- Gone Kwackers
13 Apr 2010 11:53
Unfortunately, I have no sagely words of advice as the dust boots for your bike are no longer carried by Kawasaki. However, you might watch eBay as virtually all things Kawasaki eventually appear. Those dust boots were also used on the 1982 KX80-C2...so when you are on eBay, broaden your search net.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
13 Apr 2010 13:00 - 13 Apr 2010 13:06
According to the info at Kawasaki.com, the newer -1066 seals supercede the older -037 dust shields (both are listed as Cancelled):
92093-1066 SEAL,FORK OUTER
Model (2):
KX80-C2 (KX80) (1982)
KZ250-L1 (CSR Belt) (1982)
44010-037 DUST SHIELD,FORK
Model (5):
KZ200-A1 (1978)
KZ200-A1A (1978)
KZ200-A2 (1979)
KZ250-D1 (KZ250) (1980)
KZ250-D2 (CSR) (1981)
Model (2):
Model (5):
KZ200-A1 (1978)
KZ200-A1A (1978)
KZ200-A2 (1979)
Last edit: 13 Apr 2010 13:06 by JMKZHI.
