where to get valve stems
  • loudhvx
  • loudhvx's Avatar Topic Author
03 Apr 2010 15:25
#358207
Anyone have a good link to valve stems for tubeless wheels? (Stock Enkei 7-spoke rims).
Stem part is 16126-1136
I checked Z1 and couldn't find anything.
  • gane
  • gane's Avatar
Re: where to get valve stems
03 Apr 2010 17:23
#358231
Loud, take an old valve stem to any tire store or automotive jobber, & ask for two. rubber valve stems generally come in two heights, steel in straight & 90 degree bends,occasionally w/ different rim hole diameters. you'll be fine. G
[img][/img] 1977 KZ1000A1
  • loudhvx
07 Apr 2010 00:22
#358908
Thanks, will the rubber ones work even though the stock ones are threaded steel?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
07 Apr 2010 05:09
#358928
They can be purchased through www.DennisKirk.com but they are surprizingly pricey. :blink:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Kawickrice
  • Kawickrice's Avatar
07 Apr 2010 08:52
#358967
I was just checking them out the other day in my Dennis Kirk catalog. While expensive there are may styles to choose from
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • JMKZHI
  • JMKZHI's Avatar
07 Apr 2010 10:17
#358995
You might try asking at a cycle shop - if there's one nearby. Sometimes they give stuff like that away.
  • loudhvx
07 Apr 2010 10:46
#359000
I don't actually need one from what I can tell, but everytime I go to get a tire changed, they say they don't have that type of stem and it should be replaced. I always tell them to change the tire without changing the stem and it hasn't been a problem.
However, the rubber seals are now showing signs of cracking, but are not yet leaking. Maybe I just need the o-ring or whatever type of seal is on there, but I suspect the shop will want to change the entire stem and I want to have one on hand just in case. So will a regular, rubber car stem work?
I don't have a bare wheel to even check the actual hole diameter.
  • lightitup
  • lightitup's Avatar
23 Apr 2014 01:23
#630049
i know this is a really old post but did u ever happen to change the vavle stem i need to replace my front one? and would like to go with a right angled valve stem. do u happen to remember the hole size?
81 kz 550 ltd
  • kaw-a-holic
  • kaw-a-holic's Avatar
23 Apr 2014 07:33
#630067
I have seen some on eBay. Trick ones that are at a 90. I do not know the stem size though. Call a Kaw dealer they would be able to tell you the size I bet.
Here is the 90 I was talking about.
www.powersportsuperstore.com/K-L-Supply-...5255.htm?Click=35177
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • lightitup
23 Apr 2014 07:48 - 23 Apr 2014 08:09
#630069
i found this one and i wonder if it will fit. i will give a dealer a call though
81 kz 550 ltd
Last edit: 23 Apr 2014 08:09 by lightitup. Reason: link
  • loudhvx
23 Apr 2014 09:14
#630075
I basically forgot about it... the weather must have gotten better and I went riding.
I've had a couple tires replaced since, and still haven't had an issue using the old ones.
TO find the hole size, maybe you can unscrew the locknut and just push the stem into the tire. Obviously you won't be able to get it back out without removing the tire.
  • ramtough_63
  • ramtough_63's Avatar
23 Apr 2014 13:25 - 23 Apr 2014 13:27
#630103
pm your address i'll send you a couple styles I work at a tire store LOL or just stop by a tire shop we don't charge a guy needing a couple rubber stems. have plain short long and 2 different chrome styles on hand usually
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Last edit: 23 Apr 2014 13:27 by ramtough_63.
