1976 KZ900 A4 frame. What motors will fit?
  • Krusty_47
  • Krusty_47's Avatar Topic Author
30 Mar 2010 22:42
#357371
The subject pretty much says it. I am wondering what motors I can drop directly into a KZ900 frame. Will a 1000 motor bolt right in?
1976 KZ900 A4
1980 KZ1000 G1
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 1976 KZ900 A4 frame. What motors will fit?
31 Mar 2010 02:26
#357385
Short answer...yes. BUT, just the 1015 series (the later J series are not a direct drop-in)...so, any Z1/KZ900/early KZ1000 (except E series) will fit.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Krusty_47
31 Mar 2010 03:35
#357389
ALright that's a help. I'm in the process of deciding what I want to do with my bike. I've only ridden it for a short time and it's my first bike. I want to really fix her up.
1976 KZ900 A4
1980 KZ1000 G1
  • otakar
  • otakar's Avatar
31 Mar 2010 07:24
#357421
A 76 crank case will accept a set of 1015 cylinders which can be punched to a 1075 before you drop it in. That way you only have to swap the top end. You can also use a ported "J" series head with a APE idler mount to get her really breathing. The earlier head will require quite a bit of work to get it to breathe. this way you can use your entire bottom end.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Krusty_47
31 Mar 2010 08:15
#357427
Well I hoping to put together a couple of bikes that I have laying around at my buddies house.(He just takes the forks and leaves the rest) And sell them and the extra leftover parts to fund my rebuild. So if anyone wants to help fund my rebuild I will give everyone a heads up when I have them finished. They aren't Kawasaki's though.
I was thinking about getting a 1015 or 1075 set from overstockpartsgalore.com but I'm not sure what else I would need to make sure she runs like a champ once I'm done. I know I have to send in my head to have a valve job and replace some guides. Thinking that if I cannot find someone to do it around here for cheap it's going to LarryC.
I also have ads on Craig's list to see if anyone in my area has a good running kz1000 that I can get for cheap. Which is really the reason for my post. So we'll see what I can dig up.
Wish me luck.
1976 KZ900 A4
1980 KZ1000 G1
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
31 Mar 2010 08:37 - 31 Mar 2010 09:15
#357429
79/79 MK11 and z1r will also fit.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 31 Mar 2010 09:15 by mark1122.
  • Krusty_47
01 Apr 2010 02:14
#357630
I actually just found a 77 kz1000 that I'm going to see how much he wants for it. It has 20,000 miles on it so it might be a good deal and I'm going to try to get it for less than what it would cost for a valve job. So then its just a matter of seeing which frame I want to use. So we'll see what happens.
1976 KZ900 A4
1980 KZ1000 G1
