is the lower tripple bent or the forks?
- camaroguy
29 Mar 2010 14:20
just received front end in mail. wanted to halfway assemble to make sure I got it all and it is ok. it isnt.cant tell if lower is bent or what?probably just going to dispute the amount to replace lower? any advise comments are appreciated.
bums/rr57/serviceman08/072.jpg[/IMG][IMG]
i469.photobucket.com/al
- camaroguy
Re: is the lower tripple bent or the forks?
29 Mar 2010 14:22 - 29 Mar 2010 14:27
Last edit: 29 Mar 2010 14:27 by camaroguy.
- trianglelaguna
29 Mar 2010 14:43
i think forks..cept with those materials everything i gonna be out some imo
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- thompsonmx100
29 Mar 2010 15:01
I think forks too. i would take them off and lay them on a flat surface and roll them and see if you can see any runout. Or it might just be the fact its not aligned but from the pics it looks like the forks are bent. Bummer.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- MFolks
29 Mar 2010 15:16
This is the man to go to for front fork repair:
www.frankmain.qpg.com/
- TeK9iNe
- What did you do!?!
29 Mar 2010 15:54 - 29 Mar 2010 15:57
MFolks wrote:
Ditto...
Dissasemble and check check check, especially used stuff.
Looks to me like there just not installed correctly...
The triple and lowers dont always line up the forks on there own!
Take the wheel between knees, then twist things straight. Helps to have a friend look things over while doing.
As long as everything slides up n down smoothly, you're good to go (provided you have checked to make sure noe damage/out of spec!)
GL!
Ditto...
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 29 Mar 2010 15:57 by TeK9iNe.
- porchev914
29 Mar 2010 16:19
It is n0t unusual to have your forks twist in the triples when you go down. Do what Tek9ine suggested, just loosen the pinch bolts in the triple clamps first. You don't have handlebars for leverage yet. Otherwise, it would appear from the pic you posted that the right leg is bent back below the bottom triple :ohmy: If thats the case, bummer bro
FRANKEN Z!
- camaroguy
29 Mar 2010 17:44
disaasembled front end and recheked forks. they seem to be ok.Im pretty sure the lower is tweaked. I layed it on a flat surface and with the right tube hole flat on table,the left is raised up enough in front edge to slide a steel ruler under it.got in contact with seller and was pleasantly surprised he will make good. says he has another lower for the same bike and will ship it and a few misc. other parts asap.as suggested I was able to wrestle fornt almost square with 2by slid between fork and frame.
- PLUMMEN
29 Mar 2010 19:26
id check the lower tree,kinda hard to tell from your picture
- rgoot01
29 Mar 2010 21:37
Looks like the previous forks I had on my bike. They were twisting out like yours are so I disassembled everything and checked individual fork legs. They checked out so I went to lower clamp. Come to find out after I ran a square on it
I noticed that shaft was tweaked. A little heat and a little love I was able to true it up and the result was near perfect.
Rob
Salida,CO
Salida,CO
- loudhvx
29 Mar 2010 23:23
You don't always have to dissassemble to tell if forks are bent. Just loosen the fork clamps and spin the forks. If they are bent they will bind and release as you turn them. If they rotate consistently, they are probably straight.
I don't know if upside down forks will behave the same or if you can even spin them, but it works with standard KZ forks.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- JMKZHI
30 Mar 2010 06:20
Try checking the triples separately on a glass table - push down on one corner to see if they rock. That's how I verified a bent upper triple on my 650: the bent one rocked, but the replacement didn't (the spare moved a tad but not much).
