Newbie....calipers...rebuild or.....$$$$$$$$
- HEYJACKO
- .....now what?!!
28 Mar 2010 20:21
Hi guys...I'd like to get some considered expert opinions. I'm rebuilding calipers. Have yet to have this bike on the road, not looking forward to dumping a ton of $$$ only to find out I'll have to wait 9 mos. to actually have the scratch to get this thing rolling. There seems to be considerable corrosion from the piston seal out, and a bit on the piston itself. I am considering doing a rebuild kit for all of the rubber...and a new piston if that seems warranted at this point. I have a few questions. Can I wire wheel (dremel) the seal seat, and the outer portion of the caliper along with the bolts? Is the piston too far gone or should I replace? I have scrubbed the bejezus out of these things w/toothbrush and brake fluid. AAAAAAAAAny help is appreciate. THANKS!
- HEYJACKO
- .....now what?!!
Re: Newbie....calipers...rebuild or.....$$$$$$$$
28 Mar 2010 20:22Please Log in or Create an account to join the conversation.
- HEYJACKO
- .....now what?!!
28 Mar 2010 20:37
OK...Here's a photobucket link....hope it works ok.
s41.photobucket.com/albums/e268/heyjackola/CALIPERS%20Z1B/
- timebomb33
28 Mar 2010 21:05
replace the piston and rubber parts unless there is damage done to the bore itself then a whole caliper replacement will be needed. with the pitting that is on that piston you will never get it to seal properly again or work right for that matter.
I THINK MY POWERBAND BROKE
- MFolks
28 Mar 2010 21:49
Pricey, but it's a Stainless Steel piston for the brake calipers(about mid way down on the list):http://www.americanclassix.com/kawa_improvements.html
- mtkawboy
29 Mar 2010 15:24
Thats caused by old brake fluid with moisture in it. If you reused the parts you have it will just eat up the seals in short order. Do it right & change the fluid yearly
- HEYJACKO
- .....now what?!!
29 Mar 2010 21:47Please Log in or Create an account to join the conversation.
- HEYJACKO
- .....now what?!!
29 Mar 2010 21:48Please Log in or Create an account to join the conversation.
- HEYJACKO
- .....now what?!!
29 Mar 2010 21:50Please Log in or Create an account to join the conversation.
- HEYJACKO
- .....now what?!!
29 Mar 2010 21:51Please Log in or Create an account to join the conversation.
- HEYJACKO
- .....now what?!!
29 Mar 2010 21:58
OK guys...thanks for all of the feedback. I just posted some additional pics. Sorry if I'm not gettin' it...but do you think the calipers are possible to save??? Can I take a brass wheel and carefully clean out the seats and the outer edge??? How bout the bolts, wire wheel them too? I understand the piston is probably gonzo. I've resigned myself to replacing it along with all of the rubber. I just don't want to do that if the caliper is too far gone. Thanks again for the help:woohoo: !
- donthekawguy
29 Mar 2010 23:05
The calipers are good just clean out the groove where the piston sits with the wire wheel. Replace the piston and your good to go.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
