rear sproket
- rayellis
rear sproket
26 Mar 2010 14:01
On my 1980 kz750 standard I put a 1980 kz750 LTD tire and sprocket on. I just noticed it has a 32 tooth sprocket and my original had a 33 tooth. Will this really matter and will I have to change front sprocket?
Thanx
Thanx
- StreetfighterKz
Re: rear sproket
26 Mar 2010 14:17
I doubt that you'll really notice. The LTD tire may be slightly shorter than the stock tire and the slightly smaller sprocket will offset that.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- MFolks
Re: rear sproket
26 Mar 2010 14:20
Gearing changes are something as bike owners we all do.If you want higher top speed, a smaller rear sprocket is the way to go, the drawback is slightly longer acceleration to get there.Look at this website for gearing calculations:
www.gearingcommander.com
- timebomb33
Re: rear sproket
27 Mar 2010 00:31
a one tooth change on the front is about the same as changing 3 on the back so with a 32 on there you really wouldn't see a whole lot of difference from the 33 i wouldn't worry about it myself. not enough difference to hardly even notice.
I THINK MY POWERBAND BROKE
- Old Man Rock
Re: rear sproket
27 Mar 2010 04:26
Ray, download the linked file for Sprocket & Chain Guide Selection I posted sometime ago... Covers all the math and how it effects what your looking for....
kzrider.com/index.php?option=com_docman&...d&gid=428&Itemid=108
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- djturnz
Re: rear sproket
12 Apr 2010 08:40
According to the article posted in another thread about the LTD, the sprocket change was to compensate for the different over-all height of the rear wheel/tire set up on the LTDs. It was supposed to more closely match the gearing of the standard bike.
1982 KZ750 (4) LTD
