wheel bearing detonation
  • jswag5
  • jswag5's Avatar Topic Author
  • whats the big deal about harley, i prefer 4 cyls!!
25 Mar 2010 16:56
#356142
finally got my rear wheel bearings in, when i pulled the rear wheel axle out little ball bearings went rolling and the inner race fell out of the bearing on the disc side.
i thought no problem, until i went to hammer out the outer race the wheel has a lip on the inside that does not let me get a drift onto the outer race, any suggestions?
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: wheel bearing detonation
25 Mar 2010 19:00 - 26 Mar 2010 04:01
#356181
That is probably a circlip. I have had them eaten up and really had to work to get them out.
Get the magnifying glass out and look for the break in it so you can get something worked under it. Roy
Last edit: 26 Mar 2010 04:01 by roy-b-boy-b.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
26 Mar 2010 01:04
#356238
roy-b-boy-b wrote:
That is probablt a circlip. I have had them eaten up and really had to work to get them out.
Yep...I'm thinking circlip too...the bearing body is difficult to remove w/out removing the circlip first (don't ask me how I know this :) )
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • jswag5
26 Mar 2010 06:10
#356276
the clip is on the outside of the bearing and was very easily removed before i made the post. on the inside of the wheel there is a lip that does not allow me to access the bearing to knock it out.
82 kz1000p
  • otakar
  • otakar's Avatar
26 Mar 2010 06:18 - 26 Mar 2010 06:19
#356277
I know what you are referring to. You have a big problem. There are three ways to remove that outside race. One is to heat up the rim to allow thermal expansion to do its job, the second is to chisel it out. The third is to reassemble the bearing by putting the inner race with all the balls back in. You can hold the balls in place with some five minute e-poxy or hot glue, since obviously the cage is no longer there and than knock it out the conventional way.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 26 Mar 2010 06:19 by otakar.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
26 Mar 2010 07:36
#356292
if you have a welder you can run a bead around the inside of the race and it will shrink it enough that it will fall out when turned over.
  • jswag5
26 Mar 2010 13:44 - 26 Mar 2010 14:20
#356338
thought about the welder, but all i have is a 110 gasless, did not know if it would make adhesion
i will give it a go and let you know how it works
UPDATE:
even my little 110 was enough to get heat into, no adhesion, but was enough to get the race heated up enough to drop out, thanks for the tips.
82 kz1000p
Last edit: 26 Mar 2010 14:20 by jswag5. Reason: update
