Brakes
  • rayellis
  • rayellis's Avatar Topic Author
Brakes
25 Mar 2010 15:28
#356119
Front and rear brake master cylinder on my kz750 are locked up and can not remove from master cylinder housing. The plunger/piston is not coming out easily.I have it soaking in brake fluid but not much luck in getting it out yet. Anyone, know a easy way to get this out?
I need to start ordering parts and was trying to get it so I could see if I could reuse any of these parts but now it looks at least a rebuild kit for each.
Thanks
Ray
  • MFolks
  • MFolks's Avatar
Re: Brakes
25 Mar 2010 15:42
#356126
Possibly applying compressed air to the port might be enough to force it out of the bore. I'd be careful in catching it as it will act like a projectle if not restrained.
A rubber tipped air nozzle will be able to fit tightly in those ports. I'd wear some eye protection too, as the air will tend to vaporise any brake fluid.
  • T_Dub
  • T_Dub's Avatar
Re: Brakes
25 Mar 2010 15:48
#356127
Oh man, be carful x2. I used this method to clear the pistons out of my calipers and they shot out at quite a lick.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • rayellis
Re: Brakes
25 Mar 2010 19:26
#356191
Yeah, I have done this with my calipers also and they do get going pretty fast. I tried the air on the rear but front looks almost hopeless. It did not work on the rear either but I have just removed them and need to try again.
I will give it a go tomorrow.
Thanks
Ray
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Brakes
26 Mar 2010 05:33
#356268
I used compressed air on my ZX636 calipers, works real well... Just a little blast popped them right out...
NOTE: Be careful, place a piece of wood 1/4"-3/8" between pistons where aimed down... Remove the brake bleeder nipple, short burst at a time, pops right out... ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Brakes
26 Mar 2010 06:21 - 26 Mar 2010 06:23
#356279
Lay a couple rags over caliper because when you "blast" it out, some fluid may be included. The air thing works really well. Don't just apply air, hit it sharply! :)
Last edit: 26 Mar 2010 06:23 by Bluemeanie.
