81 gpz swing arm
  • mc6767
  • mc6767's Avatar Topic Author
81 gpz swing arm
23 Mar 2010 14:16
#355673
Hi all,....I recently picked up a 81 gpz 1100....I would like a bigger back tire than stock....is there a painless bolt on solution? (bolt on wider swing arm?) thanks in advance.
  • MFolks
  • MFolks's Avatar
Re: 81 gpz swing arm
23 Mar 2010 14:27
#355676
Ask here:
www.americanclassix.com/swingarmKJSA900_150.html if they don't have what you need in stock,I'd think they can get it.
  • mc6767
24 Mar 2010 09:38
#355823
Thanks for the reply....that swing arm looks nice.....I read somewhere guys were using the swing arm from a GSXR...I think 1980's....am I mistaken?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
24 Mar 2010 11:55 - 24 Mar 2010 11:58
#355837
It is a swingarm from a GS1000 and it is a common up grade for KZ900/KZ1000...there should be plenty of threads on this site for you to data mine....for the GPz series, the common up grade is the ZRX-style swingarm (they are pricey)...see www.kipkawa.co.uk/ and look under J models
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 24 Mar 2010 11:58 by Mcdroid.
  • otakar
  • otakar's Avatar
24 Mar 2010 13:38
#355855
Actually It is from the GS1100 that guys are using. It is a box Aluminium arm that is about 1.5-2" longer than the stock. Here is one on My GPZ.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
24 Mar 2010 13:42 - 24 Mar 2010 13:44
#355856
It is not an EXACT drop in. There is some shimming required in the pivot area, but that is about all besides the longer rear axle. I am using a LTD 16" rear rim so I can put a wider tire on. I also just picke up a 18" front rim for it from a KZ1300. So I will mount that this weekend.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 Mar 2010 13:44 by otakar.
  • otakar
  • otakar's Avatar
24 Mar 2010 13:47
#355861
OH- I did forget to mention that you will require a set of Honda "Lead-wing" rear shocks. The mounts on the swingarm require clevis stile lower shock mounts. Also because the arm is a bit longer the Wing shocks are longer to compensate.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • mc6767
25 Mar 2010 12:14
#356066
amazing...thanks again...what yr is the gs1100?
  • otakar
  • otakar's Avatar
25 Mar 2010 12:43 - 25 Mar 2010 12:47
#356071
The box swing arm was on 1980-1983 GS1100E models. I built my GPz1100 from a 1981 KZ1000M (CSR) If you take a look at the bike of the month on the home page of KZR it gives you all of the specs of the bike. Also you can view the ongoing writeup on my thread.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 25 Mar 2010 12:47 by otakar.
  • otakar
  • otakar's Avatar
25 Mar 2010 12:50 - 25 Mar 2010 12:54
#356075
The 1100E swing arms are becoming harder and harder to come by. At one time you could get a nice one for about $125-$150. Now they are fetching as much as $350 or more.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 25 Mar 2010 12:54 by otakar.
  • mc6767
26 Mar 2010 10:37
#356316
your bike is a masterpiece.....thanks for the info...I may pester you some more as I get into this. (if you dont mind) :)
  • otakar
  • otakar's Avatar
26 Mar 2010 11:36
#356322
I don't mind at all. Do it on the bike build link for the bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
