Instruction for Z1 swingarm bearing kit
  • tybolt99
  • tybolt99's Avatar Topic Author
  • From where KZs came
22 Mar 2010 07:42
#355372
Can anyone give me instruction for swingarm needle bearing kit?
It is written in German.:blink: I may be able to figure out once start to put it in but want to be sure.
Thank you.
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
  • tybolt99
Re: Instruction for Z1 swingarm bearing kit
26 Mar 2010 19:28
#356432
Anybody?
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
  • timebomb33
  • timebomb33's Avatar
27 Mar 2010 00:55
#356472
i use a piece of 1/2 ready rod or all thread as some people call it with washers that are the same size as the out side diameter of the needle bearing race and pull them into place that way.don't try to drive them in as you will end up destroying the bearing race it is very thin and it will collapse if to much force is used. i freeze the bearings for at least a couple of hours and just before i'm going to put the races in i use a heat gun to heat up the swingarm. try that and it will go slick as snot. hope that helps.
I THINK MY POWERBAND BROKE
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
27 Mar 2010 05:05
#356490
Good advice and tip...thanks.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • tybolt99
27 Mar 2010 06:04
#356504
Thank you.I will definitely try that.
One bearing goes into at groove inside of swimgarm/ second flash to the end /thrust washer/washer/frame.Is this correct? No oil seal needed?
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
