universal throttle
- Darkangel
universal throttle
20 Mar 2010 14:16
Is there some where I can find a universal throttle for my 83 KZ1100
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- otakar
Re: universal throttle
20 Mar 2010 14:49
Yes, Motion Pro has a whole line of them.
www.motionpro.com/motorcycle/tools/categ...WnyKACFUKF7QodUVjFEw
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Darkangel
20 Mar 2010 14:58
our is the single push/pull
- PLUMMEN
20 Mar 2010 20:08
try suddco
- otakar
20 Mar 2010 20:48
Sudco sells the Motion pro assemblies but you can ge the cheaper straight from Motion Pro. I now buy all of my Motion Pro stuff straight from them.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Darkangel
20 Mar 2010 21:41
I agree with you there...But ours is just the std push pull throttle right..
- otakar
21 Mar 2010 06:21 - 21 Mar 2010 06:26
Kawasaki used both stiles. They used a dual cable Pull/Pull with spring return and they also used a single cable Pull with heavy spring return. I think that all of these later bikes had the single cable spring return throttle. The had was a 81 CSR throttle and it was a single cable, spring return. Motion Pro has an Excellent customer service department. If you call them and tell them what you have and what you want they will recommend the exact item you need. I believe that you require this particular throttle.
www.motionpro.com/motorcycle/partno/01-0058/
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Mar 2010 06:26 by otakar.
