rear brake upgrade
- toad
rear brake upgrade
15 Mar 2010 12:13
I'm looking for rear brake assembly for my kz1000,I would like an upgrade that would be compatible with my gs1100 swingarm and my early gsxr rim,wondering what brake caliper fits the gs axel and which brakes are a nice improvement, thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- otakar
Re: rear brake upgrade
15 Mar 2010 14:56 - 15 Mar 2010 15:01
What's a rear brake??? :laugh: Oh- I forgot it's that rusty thing on the back wheel that I always hve to scrub the rust from with sandpaper because it looks so ugly. :silly: The only time I ever use my rear brake is when I stop at a light and want to let go of the handle bars. (that is no joke) I have a GS1100 swing arm on my bike and I used the stock brake assembly that came with the bike. The only thing I also had to get was the GS link.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Mar 2010 15:01 by otakar.
- otakar
15 Mar 2010 15:05 - 15 Mar 2010 15:11
Here's a picture from the right side. The rear axle I used is from a KZ1300. It is the perfect length. The adjusters are the ones that came from the old KZ arm. The shocks I am using are made by "Progressive Suspensions", and are for a Honda Lead Wing. Because of the extra length in the arm you have to use longer shocks or you will nullify the positive handling effect of the swing arm by changing the overall geometry of the bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Mar 2010 15:11 by otakar.
- toad
15 Mar 2010 15:35
ya I've never been a huge fan of rear brakes iether, I rode all last year without any and my buddy thinks I'm nuts,oh well.I really do want to stray from the old heavy set up of the kz. What lenght are your shocks and do they have the clevis bottom, thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
15 Mar 2010 16:52
A little more use of rear brake during everyday riding may help reduce front tire cupping.
- otakar
15 Mar 2010 17:11
toad wrote:
They are about 14" and they are plug and play for the swing arm motorcycle combo. Part #12-1205B Progressive Suspensions.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- toad
15 Mar 2010 19:33
14" sounds just right , due to the 1 1/2" exra from the gs swinger.cheers
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- Galactica
15 Mar 2010 19:49
I like to balance front and rear brakes. I like to feel the bike stop nice and flat. I really dislike the diving that happens when using the front brake only. If you touch the rear brake a fraction before applying the front brake the back and will squat a bit allowing greater braking force to be applied to the front brake.
77KZ1000
76 KZ900
76 KZ900
