Questions regarding brake caliper rebuild gaskets
  • SpectreSteve
  • SpectreSteve's Avatar Topic Author
10 Mar 2010 09:24
#352436
Good morning,
I am rebuilding the rear brake caliper on my '82 KZ750 Spectre. It was stuck hard and the dust boot had rotted away. I've got the piston out of the caliper, and I am now cleaning it up and painting it. I am using acetone-based solvent to clean it up and caliper paint.
When I replace the seals and gaskets, is it a good idea to seat them in with some adhesive like Loctite or just put them right-on in?
Thanks,
Re: Questions regarding brake caliper rebuild gaskets
10 Mar 2010 10:15
#352447
If needed,here's a link to Z1E's rebuild kit for the rear caliper.
Click here > www.z1enterprises.com/detail.aspx?ID=264
Good Fortune! :)
  • timebomb33
  • timebomb33's Avatar
10 Mar 2010 10:18
#352450
use the same brake fluid that you are going to use as a lube for your orings and piston and you wont need or want any kind of sealer around those rubber pieces.
I THINK MY POWERBAND BROKE
10 Mar 2010 10:23 - 10 Mar 2010 11:30
#352451
For reference if needed, from kawasaki.com. :)
[Click on image to enlarge view.]
[Add checked items to Pick-List] REF NUMBER PART NUMBER DESCRIPTION QUANTITY US CA CN REMARKS
[Add to Picklist: 13070-1026]
13070 13070-1026 GUIDE,PAD 2
[View Supersession]
[Add to Picklist: 41080-1131]
41080 41080-1131 DISC,RR,SILVER 1
[View Supersession]
[Add to Picklist: 43020-1096]
43020 43020-1096 PISTON-COMP-BRAKE 1
[View Supersession]
[Add to Picklist: 43041-1057]
43041 43041-1057 CALIPER-ASSY,RR 1
[Add to Picklist: 43045-1007]
43045 43045-1007 SHAFT,CALIPER 1
[Add to Picklist: 43045-1008]
43045A 43045-1008 SHAFT,CALIPER 1
[View Supersession]
[Add to Picklist: 43049-002]
43049 43049-002 RING,PISTON SEAL 1
[View Supersession]
[Add to Picklist: 43056-003]
43056 43056-003 BREEDER 1
[Add to Picklist: 43057-003]
43057 43057-003 CAP,BREEDER 1
[View Supersession]
[Add to Picklist: 43082-1025]
43082 43082-1025 PAD-ASSY-BRAKE 1
[Add to Picklist: 49006-1043]
49006 49006-1043 DUST SEAL,PISTON 1
[Add to Picklist: 49006-1044]
49006A 49006-1044 DUST SEAL 2
[View Supersession]
[Add to Picklist: 92001-1951]
92001 92001-1951 BOLT,SOCKET,8X30 7
[View Supersession]
[Add to Picklist: 92001-1510]
92001A 92001-1510 BOLT,FLANGED,8X25,BL 2
[Add to Picklist: 92028-1090]
92028 92028-1090 BUSHING,SHAFT CALIPE 1
[Add to Picklist: 92081-1229]
92081 92081-1229 SPRING,PAD 1
Last edit: 10 Mar 2010 11:30 by Patton.
  • SpectreSteve
10 Mar 2010 11:21
#352471
Thanks Patton and TimeBomb33! I greatly appreciate the help and direction.
Regards,
