900 engine in 650 chassisconversion
  • timebomb33
  • timebomb33's Avatar Topic Author
Re: 900 engine in 650 chassisconversion
08 Mar 2010 10:48
#351978
turbo i might just be leaning in the direction. kawi convert i have so many of these engines i just tend to call all my big stuff 900's the fact is i don't actually have any stock bore 900's at all any more.they are all bigger 1015 and up.
I THINK MY POWERBAND BROKE
  • turboguzzi
  • turboguzzi's Avatar
08 Mar 2010 12:27
#351991
  • anarki650
  • anarki650's Avatar
08 Mar 2010 17:08
#352056
I was contemplating doing something like that once I finally get around to shoving the 1000 motor into my 77 650 cafe, would sure make it more everyday riding friendly to be able to adjust the valves without pulling the whole damn motor. Now that I have the stock 77 all ironed out I'm all out of excuses (other than no cash flow) and need to get my ass in gear on the 650 Mille (also receiving a 95 zx6 front end, swinger, brakes and suspension). I'll post LOTS of pictures once I actually get some funds scraped together to get started...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • trianglelaguna
  • trianglelaguna's Avatar
08 Mar 2010 17:15
#352058
wanna do some grafting aye???
how about a kz13000 in a gpz 550 unitrack...bet someone out there has one too...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
08 Mar 2010 17:24
#352060
Here's a 1327 cc kz650:
And a GPz1100 kz650:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rgoot01
  • rgoot01's Avatar
08 Mar 2010 18:31
#352075
if you check out my link you'll see my frame that has been stretched in the downtubes 2" and the lower frame rails 3". it's not complete however just a work in progress.
s258.photobucket.com/albums/hh243/rgoot01/
Rob
Salida,CO
  • timebomb33
08 Mar 2010 19:31
#352099
i like the stretch in the down tubes do you use solid stock it looks like you must have, also why did you stretch the lower frame rails is the the 1000 that much bigger then the 650.
  • rgoot01
  • rgoot01's Avatar
08 Mar 2010 19:45
#352108
I use solid stock turned to fit snug inside the tube. The stock also has a small key way cut in it to compensate for welded seam in the tube. I then slide a piece of tubing over area for stretch to match od of existing tubes. The stretch in the lower frame rails is more for my long legs. I am trying for a Kenny Boyce FXR style frame with some Detroit Bros. inspiration for backbone.
Rob
Salida,CO
  • timebomb33
08 Mar 2010 19:51
#352110
if i was modifing a frame for my leg lentgh i'd probably have to take two inches out. i'm just a shortass. but i really like that setup you have going on.
  • rgoot01
  • rgoot01's Avatar
08 Mar 2010 19:57
#352112
Thanks. I'll post more as I do more. Everything done to frame so far has been over the course of the last four days. This coming weekend I plan on doing the back bone so hope fully I'll have new pics by next Monday.
Rob
Salida,CO
  • Injected
  • Injected's Avatar
  • Away
10 Mar 2010 11:16
#352468
I remember somebody saying those 900 motors stick out quite a bit on the alternator side and they are heavier towards that side also - not sure if that is an issue of not with the smaller chassis and fork.
As for the valve shim issue, just saw cut the valve cover down the middle and use some 3Bond... that way when you go to lift up on the one side that seal should break (keep other side bolted down)
1978 KZ650B2 modified project
  • rgoot01
  • rgoot01's Avatar
11 Mar 2010 06:47
#352635
Why would engine be heavier on one side than the other? How much wider is the 900 engine than that of the 650. I guess what I am trying to say is, unless the engine is considerably wider than the 650 to where you would have to offset the engine to let the chain track on the two sprockets than there shouldn't be any considerable weight difference form one side to the other. However you would definately want to upgrade suspension for the extra weight of the 900.
Rob
Salida,CO
