530 off-set counter sprocket
- ds390ss123
06 Mar 2010 20:23
Anyone have any idea where a good manufacturer or supplier ? thxs
- Samwell
Re: 530 off-set counter sprocket
07 Mar 2010 02:36
ds390ss123 wrote:
APE has a selection on their site.
kzzone.com/cssprockets.html
If they don't display exactly what you need, you can always call up their customer service guys.
- Old Man Rock
07 Mar 2010 05:36 - 07 Mar 2010 05:38
Top quality, German machined one piece (no weld) CC sprockets in 530 & 630 pitch... 12mm (1/2") will allow chain to frame clearance.
americanclassix.com/streetfighter_conversions.html
No need to say more...
NOTE: If staying with the same gear ratio (15 tooth) you'll need the 18 tooth version...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 07 Mar 2010 05:38 by Old Man Rock.
- otakar
07 Mar 2010 05:37
Z1E has them fore sure. I bought one by accident.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
07 Mar 2010 05:40
You also have to tell us what engine. There are three different counter shaft splines on Kawasaki's.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- thane_420
07 Mar 2010 07:28
i got mine at
www.dgchassis.net/
call them and tell them what you want... nice to deal with. i will be oredering again soon to convert my other bike to 530 chain... good pricing also
www.dgchassis.net/
73 kz900 1075,mre clutch,race cut tranny,cams,airshift,34 flatslides, custom rear wheel
76 kz900LTD gsx-r suspension swap, mikuni 29mm smoothbores, stock engine
72 suzuki gt750 2-stroke triple
- ds390ss123
07 Mar 2010 07:55
Thanks for the info! I checked ape website already it says 630 only? but I could call them.
same for Z1E did not list a offset 530. www.dgchassis.net/ and american classix also appear to be good leads. motor is a 1980 kz1000
- z1kzonly
07 Mar 2010 09:09
