Adding a Tailpiece to a 650SR
- sabell
05 Mar 2010 07:48 - 05 Mar 2010 07:49
I have always liked the front on the SR(d) model(mostly the tank), and the ass end of the standard KZ. Is the seat pan the only difference on these models to allow a tail piece to be added or should I expect some mods to both. I added a tail piece to a SR I had back in the mid '80's but I don't think it was even from a Kaw and I butchered the seat as well. A few to many good times since then and three kids has clouded the memory of the project since then.
'78 KZ1000A2
'79 650SR
'79 650SR
Last edit: 05 Mar 2010 07:49 by sabell.
- otakar
Re: Adding a Tailpiece to a 650SR
05 Mar 2010 08:39
I think you will be lacking all the mounts to mount the duck tail. i had to do the same thing to my GPz. If you look at the thread, it will show you what I did to mount mine.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- N0NB
- Blue handles better
05 Mar 2010 17:37
The rear frame geometry is different between the D models and the B/C models.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- rstnick
05 Mar 2010 19:00
The frame is different, and lacks the mounts, but it can be done.
There is a nice red 650 D(SR) in the gallery somewhere.
Looks good with a tail.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
05 Mar 2010 19:16
Found the red one, and a blue one too:
kzrider.com/index.php?option=com_joomgal...l&id=1624&Itemid=117
kzrider.com/index.php?option=com_joomgal...l&id=3001&Itemid=117
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- sabell
05 Mar 2010 20:30
Thanks rstnick. Both nice bikes, I think the blue one is the look I'm after though. Hopefully mine pops up as a project before to long.
'78 KZ1000A2
'79 650SR
'79 650SR
- otakar
06 Mar 2010 06:06
I think that a tail from a ZN700/750/1100 would look nice on the bike. I think that it could be mounted with out much effort. The frame on my 1000CSR was also quite a bit different than the one on the GPz1100. It took me about a day to figure it out and mount the tail.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- sabell
06 Mar 2010 07:09
I will check out that tail Otto, but now you may have motivated me to try building one from scratch with fiberglass. Being a carpenter by trade, I could whip out a form pretty quick then skin it and see what happens. Going this route I could incorporate mounting locations that jive with the frame better. I'm a little worried it may come out looking somewhat boxy until I figure how to get some contours. Seems I've seen somewhere that tin foil is used in between the form and the glass to ease in seperation...is that right?
'78 KZ1000A2
'79 650SR
'79 650SR
- otakar
06 Mar 2010 07:50 - 06 Mar 2010 07:52
If you use The open cell insulation foam (not the white closed cell) Carve your tail piece just like you want it. Use Epoxy resin not Poly Ester resin to build the tail piece This resin will not attack the foam. If you want to use Poly Ester resin first use a good coat of Polly Urethane (oil based) varnish to coat it. Than you pain it with PVA (this is a water soluble release barrier. Than you can build up the cloth any way you want to. To remove the plug once the glass is cured just dig it out with a putty knife. It will come out very easy. Once the majority of the foam is removed just soak it in water and the rest will come right off. This is how you do it over a MALE plug. It is very simple. To do it into a Female mold is much more complicated. This fairing was built over an original GPz550 fairing and than popped off I used PVA and wax as a release agent.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 06 Mar 2010 07:52 by otakar.
- sabell
06 Mar 2010 08:05 - 06 Mar 2010 08:06
Thanks for the tips, I just may have to give it a shot. Found a couple of tails on Ebay that you referred to, I like the way the tail light tucks in there.
'78 KZ1000A2
'79 650SR
'79 650SR
Last edit: 06 Mar 2010 08:06 by sabell.
- otakar
06 Mar 2010 08:19
No eBay APP ID and/or Cert ID defined in Kunena configurationThese are designed to mount to the inner fender and not to the frame like all the others.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
