caliper cleaning putting piston back in
- morhaven
18 Feb 2010 05:30
Hi guys, I picked up a 82 kz1100 spectre last month.
Front brake caliper was seized. So I tackled it last night.
Drained the bad fluid out, took it off the bike.
Popped the piston out with Compressed air.
The seals are in great shape and so is the piston. i cleaned all the bad brake fuild inside .
My problem is I can't seem to be able to push the piston back in..whats is trick for this?
I did not take the seals off as they are in great shape and clean.
- rstnick
Re: caliper cleaning putting piston back in
18 Feb 2010 06:26 - 18 Feb 2010 06:27
A bit of brake fluid could help. Put a bit all around and on the seal.
I'd be thinking of replacing the seal. It's probably some years old. May look fine, but a new one is cheap and will last longer.
Replace the dust seal too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 18 Feb 2010 06:27 by rstnick.
18 Feb 2010 07:34 - 18 Feb 2010 07:34
Last edit: 18 Feb 2010 07:34 by Patton.
- jimstan
18 Feb 2010 18:18
Try using a small block of wood and a C clamp, they can be very very tight.
Good luck
Jim
Good luck
Jim
18 Feb 2010 18:30
Is the bleeder open or removed so the air can get out from behind the piston? Ed
- donthekawguy
19 Feb 2010 03:47
You have to take the seal out and clean the groove with a wire wheel on a dremmel. I have never seen one that didn't have a lot of corosion in the groove. When thats done use a bit of fluid on the seal and the piston will go right in.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- testarossa
19 Feb 2010 04:41
donthekawguy wrote:
+1 That crud under the seal is what makes the caliper get sticky. You'll never see it unless you remove the seal.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- timebomb33
19 Feb 2010 08:49
brake fluid will cyrstyalize over time due to evaporation it will get in behind the seals andforce them out a bit which causes the sticking problem in the first place remove the two piston seals and clean out the reciever grooves very well and also clean up the seals if they are pitted replace them then when you are reinstalling them lube them up good with the same brake fluid you are using in the brake system, dont use any other kind of lube and the pistons should slide in easily.
I THINK MY POWERBAND BROKE
