Z1R 18" Wheel
- seanof30306
Z1R 18" Wheel
15 Feb 2010 14:18
So, I sniped an auction for an 18" Z1R wheel on ebay and have been congratulating myself ever since.
I got the wheel today, however, and when I run a tape measure across the wheel, I get 19 1/8".
Is the seller the one chuckling?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- T_Dub
Re: Z1R 18
15 Feb 2010 14:27
Isn't 18" the diameter of the inside of the tire? So I can see the wheel measuring more.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Bad Dad
Re: Z1R 18
15 Feb 2010 14:34
I'm with T_Dub on this one... it's the inner part of the rim, not the outter most part. Is it the rear, or the front, ZIR wheel? All the rears were 18", but I think they had both 18"&19" fronts?
Tony
Tony
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- seanof30306
Re: Z1R 18
15 Feb 2010 14:36
I guess that makes sense if the operative measurement is the tire, bead-to-bead. The lip on the wheel measures 9/16". Doubling that to account for the other lip comes to 1 1/8". Subtracting that from 19 1/8" comes to 18". I hope that means I'm OK.
Does anyone have a regular 19" mag off the bike with no rotor that they could measure?
Thanks
Thanks
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- seanof30306
Re: Z1R 18
15 Feb 2010 14:37
Z1R had an 18" front rim for one year, I believe.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- T_Dub
Re: Z1R 18
15 Feb 2010 14:37
It'd help if you had a pic.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- seanof30306
Re: Z1R 18
15 Feb 2010 14:40 - 15 Feb 2010 14:40
Sorry, no cam. The rims look identical, though, so I don't see where it'd make a difference.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 15 Feb 2010 14:40 by seanof30306.
- T_Dub
Re: Z1R 18
15 Feb 2010 14:53
And its definitely a rear wheel? I've never heard of a 19" rear cast wheel from the 70's.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- seanof30306
Re: Z1R 18
15 Feb 2010 15:01
No, it's a front wheel
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- otakar
Re: Z1R 18
15 Feb 2010 15:07 - 15 Feb 2010 15:16
The size is clearly cast into the rim. This one is 18" and is 2.15 wide. this rim is from a KZ1300. Yes and it measures 19 1/8"
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Feb 2010 15:16 by otakar.
- T_Dub
Re: Z1R 18
15 Feb 2010 15:07
Sorry, I didn't understand. Hopefully someone else reads this, I'd measure my 19" front but its 100 miles away.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- Mcdroid
- Gone Kwackers
Re: Z1R 18
15 Feb 2010 15:09 - 15 Feb 2010 15:13
yes...I have several 19" front wheels I could measure...one off a 1982 KZ750R1 should measure the same as the D model. Otokar is correct...the size should be cast into the wheel...mine is cast as a 19" and measures 20" across the rim - edge to edge.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 15 Feb 2010 15:13 by Mcdroid.
