Will 650-E1 forks fit a B1?
  • 77_650B1
  • 77_650B1's Avatar Topic Author
27 Mar 2006 15:00
#34736
I've got a 77 KZ650B1, and I'm wondering if the forks off a 1980 650 LTD will fit it. All I'm concerned with is the length, diameter, and whether a wheel from a 650 custom will fit as well. Thanks. If they fit, I'll be getting them and putting them in my original triple tree and also getting an alloy wheel for the front. Just want to know what to do, as I cant find much literature on the subject and couldn't find any on here.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Will 650-E1 forks fit a B1?
27 Mar 2006 21:37
#34851
Never seen it done before. Are the diameter the same? The forks are probably longer too.
OK, I looked at the parts diagrams, and they both share the same upper and lower steering stems (tripple clamps), so the diameter is the same. The forks are a different part number, so are probably a different length.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
