Fork spring installation - which way?
- savedrider
- 1975 Z1-B 900
06 Feb 2010 14:30
The springs have one end that is coiled tighter for about 2 inches. Does this end face up towards the tube cap or down towards the tube bottom?
I didn't pay attention when I took it apart and the manual I have doesn't specify. I looked at the other fork I haven't done yet and they are at the top, but I wanted to double check. I'm pretty sure it doesn't make much difference either way, but I've done other bikes where it is specific.
Thanks!
Thanks!
Get right or get left! <*{{{><
- PLUMMEN
Re: Fork spring installation - which way?
06 Feb 2010 15:56
tapered end of spring goes on the bottem
- keith1
06 Feb 2010 16:23
the directions that came with my progressive suspension springs said that it didnt matter....
- savedrider
- 1975 Z1-B 900
06 Feb 2010 16:28
Ok, I'll put the tapered/coiled end on the bottom. Guess I had them in upside down before, at least on the left side.
I put Progressive springs in my VFR and I recall it said it didn't matter too.
Thanks
Thanks
- savedrider
- 1975 Z1-B 900
06 Feb 2010 16:44
Ok I'm confused, I can't determine which end has a taper. Look and measure pretty much the same.
- savedrider
- 1975 Z1-B 900
06 Feb 2010 16:47
Copied this from a Prgressive installation guide:
Install your new fork springs into the forks. Mechanically, it
makes no difference which way the springs are installed. Some
manuals will state; install the spring with the close wound end towards
the bottom. This is done because sometimes there will be
less spring noise. The springs will perform exactly the same regardless
of which direction they are placed.
So I'm going with close coiled end down.
- gane
06 Feb 2010 17:12
The Pros Know.. At my Pappa's Knee, was told the tight wind goe's to stationary end.. However, w/ forks which specify cc amounts of oil only, I install w/tight winds down,hopefully raising oil level (slightly)& reducing possible ariation. G
[img][/img] 1977 KZ1000A1
08 Feb 2010 19:13
As Plummen said, tapered end down. Ed
