lowering forks
  • eyeofthestorm
  • eyeofthestorm's Avatar Topic Author
  • its KZ kraziness!
lowering forks
27 Jan 2010 23:17
#345032
is there a way to drop an inch or two inches out of the front end of a 78 kz650? havent had any luck finding lowering springs or anything for it. id prefer lowering it to raking it out. thanks!
  • TerryK
  • TerryK's Avatar
Re: lowering forks
27 Jan 2010 23:28
#345034
If you want it done right you'll have to have spacers made for the damper rods in the forks and cut the springs to match. Remember, when you cut the springs it increases the spring rate.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • camaroguy
  • camaroguy's Avatar
Re: lowering forks
28 Jan 2010 03:38
#345042
can you raise the forks up into the triples? if you have to put some riser mounts on to raise the bars for clearance.
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
Re: lowering forks
28 Jan 2010 11:05
#345088
See circled area. About 1.5" (38mm) frame neck drop by shoving the forks up.
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
  • timebomb33
  • timebomb33's Avatar
Re: lowering forks
28 Jan 2010 11:17
#345091
the best way to do it is internally like terry said
I THINK MY POWERBAND BROKE
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: lowering forks
28 Jan 2010 11:31
#345094
Internal lowering blocks are definitely the "correct" way to do it. The blocks are cheap but you have take apart your forks to install them. Here's what they are:
www.schnitzracing.com/manuals/KZ-GSLoweringBlocks.htm
www.schnitzracingstore.com/catalogs/cata...67677&showprevnext=1
The Kaw List:
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: lowering forks
28 Jan 2010 11:43
#345097
I've done both the internal and external with equally good results.
The internal method looks best and performs a little better than stock if you match the spring rate with the rear. It requires much more effort to complete, as said...
External method makes very little difference in performance, but provides the desired drop with little effort. Final appearance is ok, but obvious.
Whatever you like...
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • mookieo2
  • mookieo2's Avatar
Re: lowering forks
30 Jan 2010 06:03
#345342
Why don`t you just loosen the triple clamps and drop it down. I just dropped mine 25mm. It takes 10 mins.
  • eyeofthestorm
  • its KZ kraziness!
Re: lowering forks
10 Feb 2010 21:42
#347678
i have had them lowered in the tripples before, but with the new bars i made they only slide down about 3/4" before they hit the underside of the bar. i could do some risers but thats ugly and obvious and changes the position of my bars which ive spent alot of time cutting and welding to get right, lol. i guess ill have to look into the lowering block system. thanks guys
